Старый 16.06.2007, 11:20   #1
jerry-dynamics: dimensions hierarchy controls
Источник: http://jerry-dynamics.org/2007/06/10...rchy-controls/
1.A controller would like to assign a department 60-Purchase and cost center 6010-Purchase when the accounts payable administrator creates vendor journals. Which of the following needs to be defined to restrict the available selections?
<span lang="EN-US" />A: Dimension proposal
B: Dimension planning
C: It can not be done
D: Dimension set hierarchyCorrect Answers: D
The dimensions hierarchy controls and validates dimension values at entry time in the user’s context. For example, the order processor is guided to enter specific dimension values when setting up new vendors. It is necessary to activate a specific configuration key for the dimensions hierarchy.
Solutions Monkey: Using Microsoft Dynamics Ax 2009 Workflow controls in EP Blog bot DAX Blogs 0 30.07.2008 10:05
jerry-dynamics: tax codes Blog bot DAX Blogs 0 16.06.2007 11:20
jerry-dynamics: sequentially numbered checks in the bank module Blog bot DAX Blogs 0 16.06.2007 11:20
jerry-dynamics: What tool would be appropriate to use before you click the button to import into AX 4.0? Blog bot DAX Blogs 0 16.06.2007 11:20
Часовой пояс GMT +3, время: 12:18.
