Старый 16.06.2007, 11:20   #1
jerry-dynamics: What tool would be appropriate to use before you click the button to import into AX 4.0?
Источник: http://jerry-dynamics.org/2007/05/20...priate-to-use/
Questions You have received an xpo-file containing modified application objects. What tool would be appropriate to use before you click the button to import into AX 4.0? A: Application Hierarchy Tree B: Application objects C: Code Explorer D: Compare
Dynamics AX: Migration Tool for Microsoft Dynamics AX 2009 - Release Blog bot DAX Blogs 0 25.11.2008 02:08
Arijit Basu: PerformancePoint Server 2007 Tool: Data Import Wizard for Microsoft Dynamics AX Blog bot DAX Blogs 0 22.01.2008 21:33
Часовой пояс GMT +3, время: 02:06.
