#1 |
jerry-dynamics: sequentially numbered checks in the bank module
Источник: http://jerry-dynamics.org/2007/06/13...e-bank-module/
============== Your company wants to generate a number of sequentially numbered checks in the bank module. Which of the following is a requirement to allow sequentially numbered checks? A: Set up a number sequence on the check layout. B: Select Automatic check numbering in the Parameters. C: Create a Check group and define the number sequence. D: Select Fixed in the check numbering method. Correct Answers: D In the Check number method field, select the method to use for generating check numbers. Select one of the following: .Fixed Use this method when pre-printed checks exist. Before using checks for payment, they must be created by clicking the Create checks button in the Bank account window. .Free Use this method when pre-printed checks do not exist. Microsoft Dynamics AX 4.0 automatically proposes check numbers when using checks for payment Источник: http://jerry-dynamics.org/2007/06/13...e-bank-module/
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
