Старый 02.08.2018, 18:12   #1
d365technext: Override Lookup AX7 & D365FO
Источник: http://d365technext.blogspot.com/201...x7-d365fo.html
Here is the small example to override lookup ..
copy the lookup event handler of the field and paste the event into any class
/// receiving value in parameter
[FormControlEventHandler(formControlStr(PayrollEmployerTaxRegion, Overview_StateId), FormControlEventType::Lookup)]
publicstaticvoid Overview_StateId_OnLookup(FormControl sender, FormControlEventArgs e)
/// write your lookup code here
if control or field already have lookup to we need to cancel parent lookup execution otherwise we will get exception.
below code you can use to cancel parent lookup ---
FormControlCancelableSuperEventArgs ce = e asFormControlCancelableSuperEventArgs;
//cancel super() to prevent error.
ce.CancelSuperCall();
Here is the complete code sample
SysTableLookup sysTableLookup = SysTableLookup::newParameters(tableNum(LogisticsAddressState), sender);
Query query = newQuery();
// Filter lookup to only show US states
query.addDataSource(tableNum(LogisticsAddressState)).addRange(fieldNum(LogisticsAddressState, CountryRegionId)).value(LogisticsAddressCountryRegion::findByISOCode(SysCountryRegionCode::countryInfo(curext())).CountryRegionId);
// Sort the lookup by state Id
query.dataSourceTable(tableNum(LogisticsAddressState)).addOrderByField(fieldNum(LogisticsAddressState, StateId), SortOrder::Ascending);
// Add fields
sysTableLookup.addLookupfield(fieldNum(LogisticsAddressState, StateId));
sysTableLookup.addLookupfield(fieldNum(LogisticsAddressState, Name));
// Run lookup
sysTableLookup.parmQuery(query);
sysTableLookup.performFormLookup();
За это сообщение автора поблагодарили: IvanS (1).
d365technext: Environment Hot-Fixes List Using X++ D365FO & AX 7 Blog bot DAX Blogs 0 02.08.2018 18:12
d365technext: Card Pattern in Grid D365FO & AX 7 Blog bot DAX Blogs 0 02.08.2018 11:11
d365technext: Batch Multi threading D365FO AX7 Blog bot DAX Blogs 0 31.07.2018 23:16
ievgensaxblog: D365FOE. How to override form data source field lookup method. Blog bot DAX Blogs 0 10.01.2018 05:11
Microsoft Dynamics CRM Team Blog: What’s new in the Lookup control with Microsoft Dynamics CRM 2013 Blog bot Dynamics CRM: Blogs 0 04.12.2013 04:13
Часовой пояс GMT +3, время: 06:35.
