Старый 02.08.2018, 18:12   #1
d365technext: Environment Hot-Fixes List Using X++ D365FO & AX 7
Источник: http://d365technext.blogspot.com/201...t-using-x.html
We All knows that information about metadata hotfixes installed directly from Visual Studio and we can check them Using Apply Hotfix Addins(Dynamics 365 -> Addins -> Apply Hotfix).
The same things we can retrieve using X++ Job
Result
Code Sample
class SLD_DemoClass
public static void main(Args _args)
new SLD_DemoClass().processExecution();
public void processExecution()
var environment = Microsoft.Dynamics.ApplicationPlatform.Environment.EnvironmentFactory::GetApplicationEnvironment();
Microsoft.Dynamics.AX.Metadata.Providers.IMetadataProvider metadataProvider =
this.getDiskMetadataProvider(environment);
Microsoft.Dynamics.AX.Metadata.Providers.IMetaUpdateProvider updateProvider = metadataProvider.get_Updates();
var moduleInfoList = metadataProvider.ModelManifest.ListModules();
var i = moduleInfoList.GetEnumerator();
setPrefix('Installed KBs on your Instance');
while (i.MoveNext())
Microsoft.Dynamics.AX.Metadata.MetaModel.IModuleInfo moduleInfo = i.get_Current();
System.String moduleName = moduleInfo.get_Name();
setPrefix(moduleName);
var updatesHotfixesEnumerator = updateProvider.ListObjects(moduleName).GetEnumerator();;
while (updatesHotfixesEnumerator.moveNext())
System.String axUpdateName = updatesHotfixesEnumerator.get_Current();
Microsoft.Dynamics.AX.Metadata.MetaModel.AxUpdate axUpdateObject = updateProvider.Read(axUpdateName);
utcdatetime installedDateTime = axUpdateObject.get_AppliedDateTime();
setPrefix(strFmt('Name %1, Installed on %2', axUpdateObject.get_Name(), installedDateTime));
var listKb = axUpdateObject.get_KBNumbers().GetEnumerator();
while (listKb.MoveNext())
info(listKb.get_Current());
public Microsoft.Dynamics.AX.Metadata.Providers.IMetadataProvidergetDiskMetadataProvider(Microsoft.Dynamics.ApplicationPlatform.Environment.IApplicationEnvironment _Instance)
Microsoft.Dynamics.AX.Metadata.Storage.DiskProvider.DiskProviderConfigurationdiskProviderConfiguration = new Microsoft.Dynamics.AX.Metadata.Storage.DiskProvider.DiskProviderConfiguration();
diskProviderConfiguration.AddMetadataPath(_Instance.get_Aos().get_PackageDirectory());
Microsoft.Dynamics.AX.Metadata.Storage.MetadataProviderFactorymetadataProvicerFactory = new Microsoft.Dynamics.AX.Metadata.Storage.MetadataProviderFactory();
returnmetadataProvicerFactory.CreateDiskProvider(diskProviderConfiguration);
stephenmann: Technical History of Dynamics AX - From Axapta 3.0 to AX2012 Blog bot DAX Blogs 5 03.03.2017 10:22
atinkerersnotebook: Self Service Reporting for Dynamics AX Users – Part 3: Adding Additional Fields to List Page Views Blog bot DAX Blogs 0 07.10.2015 18:11
dynamics-ax: Open AX & PTC FlexPLM Positions! Blog bot DAX Blogs 0 02.12.2010 00:11
jinx: Dynamics AX AIF Webservices – Date, Time und Datetime Datentypen Blog bot DAX auf Deutsch 0 12.06.2010 01:05
Часовой пояс GMT +3, время: 01:11.
