Старый 16.11.2017, 10:11   #1
ievgensaxblog: D365FOE. FormHasMethod extension for form extension methods.
Источник: https://ievgensaxblog.wordpress.com/...nsion-methods/
Recently I have seen multiple people asking how to check if form has method added by extension at run-time.  For form methods we can use Global::formHasMethod but it does not work with form extensions. I advised people to use new metadata API to do this and finally community user Axaptus wrote the code!
I tweaked it a bit to ignore method’s name case as AX does and to exclude private methods. Also I used it to extend standard formHasMethod method
/// <summary>
/// The class <c>Global_Extension</c> contains extension methods for the <c>Global</c> class.
/// </summary>
[ExtensionOf(classStr(Global))]
public static final class Global_Extension
    static boolean formHasMethod(FormRun fr, IdentifierName methodName)
        boolean ret = next formHasMethod(fr, methodName);
        if (!ret)
            ret = Global::formExtensionHasMethod_IM(fr, methodName);
        return ret;
    private static boolean formExtensionHasMethod_IM(FormRun _formRun, IdentifierName _methodName)
        if (!_formRun || !_methodName)
            return false;
        boolean ret = false;
        try
            System.Object[] extensions = Microsoft.Dynamics.Ax.Xpp.ExtensionClassSupport::GetExtensionsOnType(_formRun.GetType(), true);
            if (extensions)
                System.Type    formRunExtensionType;
                System.Reflection.MethodInfo    methodInfo;
var bindingFlags = BindingFlags::Public | BindingFlags::Instance | BindingFlags::Static | BindingFlags::IgnoreCase;
for (int i = 0; i < extensions.Length; i++)
                    formRunExtensionType = extensions.GetValue(i);
                    methodInfo = formRunExtensionType.GetMethod(_methodName, bindingFlags);
                    if (methodInfo)
                        ret = true;
                        break;
        catch (Exception::CLRError)
            error(CLRInterop::getLastException().ToString());
        return ret;
Extending standard method has its pros and cons. From one side it will slow down execution of standard code that calls it when method does not exist, but it’s a rare case. From another side it allows you to reuse standard code without changing it and it could be handy in various places where AX looks for a method on a form.
Source code is available on GitHub
Последний раз редактировалось mazzy; 16.11.2017 в 10:19.
За это сообщение автора поблагодарили: Jorj (1).
ievgensaxblog: D365FOE. Issue with enums that have “Use Enum Value” property set to “No”. Blog bot DAX Blogs 0 15.10.2017 11:12
newdynamicsax: Code behind extension forms: How to add state variables and override methods without overlayering Blog bot DAX Blogs 0 12.10.2016 06:25
goshoom: Class extensions Blog bot DAX Blogs 0 18.07.2016 17:11
mfp: X++ in AX7: Extension methods Blog bot DAX Blogs 10 17.12.2015 18:22
axaptapedia: Table Methods Generator Blog bot DAX Blogs 0 13.02.2009 02:05
Часовой пояс GMT +3, время: 00:46.
