Старый 18.07.2016, 17:11   #1
goshoom: Class extensions
Источник: http://dev.goshoom.net/en/2016/07/class-extensions/
The new Dynamics AX (AX 7) attempts to minimize overlayering (“customization”) and promote extensions, which allow adding functionality without modifying source code of the original object. For example, you now can attach a field to a table without changing the definition of the table itself. It has many benefits – no changes in existing objects mean no code conflicts and much easier upgrades, it’s not necessary to recompile the original object and so on.
AX 7 RTW introduced extension methods – if you’re not familiar with them, look at my description and an example in New X++ features in AX 7. In short, extension methods are static method defined in a completely different class, yet they can be called in the same way at if they were instance methods of the “extended” class, table or so.
Update 1 added something called class extensions, which allows adding not only methods, but also class variables, both instance and static, constructors and static methods.
For example, the following piece of code augments the standard Dialog class with a variable and methods working with the variable:
[ExtensionOf(classStr(Dialog))]final class MyDialog_Extension{ private int x; public void setX(int _x) { x = _x; } public int getX() { return x; }}
You can use these methods directly on the Dialog class:
Dialog d = new Dialog();d.setX(50); int x = d.getX();
As you would expect, the value set by setX() is stored in the variable and you can retrieve it by calling getX().
But how does it really work? How Dialog class knows about these new methods and where is the value actually stored, if it’s all defined in a completely different class?
You might think that MyDialog_Extension inherits from Dialog and replaces the Dialog class, it’s a partial class or something like that, but it’s not the case.
The methods are actually extension methods as we know them from AX 7 RTW. Don’t get confused by the fact that we declare them as instance methods; they’re converted to normal static extension methods under the hood. For example:
// This instance method in the extension class…public void setX(int _x) { … } // …is converted to a static extension method like this:public static void setX(Dialog _dialog, int _x) { … }// As usual, the first argument is object to which the extension methods applies.
The conversion happens when X++ is compiled to CIL and you normally don’t have to bother about it; I’m mentioning it to demonstrate that it’s really just a normal extension method.
Generating different CIL than what you see in X++ might look weird, but it’s a common way to extend CLI (“.NET”) languages without changing the Common Language Runtime (CLR). For example, if you use async keyword in C#, C# compiler uses standard CLR constructs to generate a whole state machine that handles asynchronous processing. Because CLR receives normal CIL code, it doesn’t need to know anything about X++ class extensions nor C# async/await.
All right, so methods in class extensions are just common extension methods, which explains how methods are “attached” to the augmented class. But where AX stores the variables? How can static methods of the extension class access instance variables?
Again, the solution isn’t too complicated. Under the hood, the extension class has a static variable which maintains references between instances of the augmented class and instances of the extension class. In my case, it maps instances of Dialog and MyDialog_Extension.
When I call a method of my MyDialog_Extension, it gets a Dialog instance as the first argument. It looks into the static map, obtains the corresponding MyDialog_Extension instance (it might have to create it first if it doesn’t yet exist) and then it accesses its fields.
The following code is a simplified demonstration of how it works.
// A demonstration - not the real implementationfinal class MyDialog_Extension{ private int x; private static Map mapDialogToExtension; public static void setX(Dialog _dialog, int _x) { MyDialog_Extension extension = mapDialogToExtension.lookup(_dialog); if (!extension) { extension = new MyDialog_Extension(); mapDialogToExtension.insert(dialog, extension); } // Here we're accessing the instance variable extension.x = _x; }}
Now it’s clear that extension classes don’t modify their augmented classes in any way. All variables declared in an extension class are stored in its instances – it’s rather similar to joining two separate tables.
Because extension classes merely get instances of augmented classes by references, they can’t access its internal state or call private methods.
You can also attach static methods and class fields (variables and constants).
Using static methods in class extensions is useful because it’s easier to find static methods on the corresponding class rather in some utility classes. It also allows you to add methods to the Global class and call them without specifying any class name.
Using static fields can also be very useful. The following example shows adding a new operator (implemented as a public constant) to DimensionCriteriaOperators class.
[ExtensionOf(classStr(DimensionCriteriaOperators))]final static class MyDimOperators_Extension{ public const str MyNewOperator = '!';}
As with methods, the new constant seems to be a part of the augmented class, although it’s declared somewhere else.
In some cases, such a static class with public constants can be a natural replacement of extensible enums.
If you use a static method or a static variable, CIL generated by X++ compiler directly refers to the extension class.  For example, DimensionCriteriaOperators::MyNewOperator is translated to exactly the same CIL code as MyDimOperators_Extension::MyNewOperator. The fact that X++ presents it in a different way is purely for developers’ convenience.
As you see, class extensions are really an evolution of extension methods. Instance methods in class extensions are based on extension methods; they “merely” add a the option to work with instance variables. And there a few other useful features, namely constructors and static members.
The main purpose of class extensions is to help with getting rid of overlayering, but that’s not the only use. They have potential to change how we traditionally design certain things in AX, especially if somebody comes with a common framework based on extensions, as LINQ revolutionized how we work with collections in C#.
For example, are you aware of that you can write extension methods working with all table buffers by extending Common? Like this:
[ExtensionOf(tableStr(Common))]final class Common_Extension{ public List getSelectedRecords() { List selectedRecs = new List(Types::Record); if (this.isFormDataSource()) { MultiSelectionHelper helper = MultiSelectionHelper::construct(); helper.parmDatasource(this.dataSource()); Common rec = helper.getFirst(); while (rec) { selectedRecs.addEnd(rec); rec = helper.getNext(); } } return selectedRecs; }}
The possibilities are unlimited.
I hope I didn’t overwhelm you with technical details – it may be challenging especially if you’re not familiar with C#, where we use things like static members and extension methods for years. But I believe that understanding the inner workings is often very helpful for using language features correctly and debugging code if it doesn’t work as expected.
german_nav_developer: Dynamics NAV 2013 R2 multi-tenancy – Viele Mieterinnen ohne Stress und Neid Blog bot Dynamics CRM: Blogs 0 30.12.2013 19:00
ax-erp: Walkthrough: Creating a Report Bound to a Report Data Provider Class (X++ Business Logic) [AX 2012] Blog bot DAX Blogs 0 20.09.2012 11:11
german_nav_developer: Codepage und Multilinguale Dynamics NAV Installationen Blog bot Dynamics CRM: Blogs 0 05.06.2011 15:51
Kashperuk Ivan: List panels in Dynaics AX - a short description of SysListPanel class Blog bot DAX Blogs 1 21.10.2007 22:51
Kashperuk Ivan: Description of ClassBuild class:Today I want to ... Blog bot DAX Blogs 0 26.01.2007 05:51
Часовой пояс GMT +3, время: 10:22.
