Старый 14.09.2017, 13:11   #1
thwidmer: Comparison: “Use futures date as requirement date”
Источник: https://thwidmer.wordpress.com/2016/...uirement-date/
Setup
Master plan setup – Use futures date as requirement date
pl-PO Use Futures date as Requirement date = Yes
pl-PO Use Futures date as Requirement date = No
pl-PO + pl-Prod Use Futures date as Requirement date = No
Coverage group – Action Basis Date
Action Basis date = Requirement date
Action Basis date = Futures date
Test cases
Scenario
Sales order with confirmed delivery date: 16.11.2016; the lead time setup of the purchase item (M0009) doesn’t allow the PO to be on time.
pl-PO Use Futures date as Requirement date = Yes; Action Basis date = Requirement date
pl-PO Use Futures date as Requirement date = Yes; Action Basis date = Futures date
pl-PO Use Futures date as Requirement date = No; Action Basis date = Requirement/Futures date
Note: Changing Action Basis date does not have an affect
pl-PO + pl-Prod Use Futures date as Requirement date = No; Action Basis date = Futures/Requirement date
Recommendation
USE: Use Futures date as Requirement date = Yes; Action Basis date = Requirement date
With this setting the system tells you what is late and what you should try to do about it.
NAV Team: Shipment date vs. Posting date vs. Due date Blog bot Dynamics CRM: Blogs 0 26.09.2013 18:36
daxsol: Axapta Kernel Functions Blog bot DAX Blogs 1 16.05.2009 19:22
И вновь о вызове хранимой из Аксапты Protey DAX: Программирование 52 04.10.2005 12:35
Часовой пояс GMT +3, время: 04:29.
