Старый 26.03.2016, 04:15   #1
organicax: Setting up an Android emulator with the warehouse mobile device
Источник: http://organicax.com/2016/03/25/sett...mobile-device/
If you are working with a scanner that runs an operating system, most likely it would have been Windows CE, Windows Embedded for example. Now there are devices that run Android. So you if you are looking at getting one of these devices then you might want to use a Android emulator when you are testing the AX warehouse mobile device portal.
There is an option that can integrate with Visual Studio or as a stand alone install. You can find it here called the Visual Studio Device Emulator for Android
https://www.visualstudio.com/en-us/f...ulator-vs.aspx
One of the nice things about this emulator is that it has a range of Android images that you can use JellyBean, KitKat, Lollipop, Marshmallow for example so you can look for what you scanner device might be running. These images are more focused on the phone but the foundation will be similar if a scanner device manufactuer took a distribution as the basis for their device.
Now there are a few pre-reqs to run it, namely the Android images are installed via a virtual machines that run under Hyper-V. So you will need to be running an operating system that runs Hyper-V. I’m my example I’m just using Windows 10. As you as talked about in the video you will need some networking knowledge to be able to connect the running device to networks with Hyper-V and the other VM or server running AX.
Once you have it setup the AX experience is the same because the mobile device is just a web page so it works pretty well.
Here is a quick overview.
AX2012 R3 CU9. While I was using CU9 this isn’t a dependency for AX.
In the video a well I’m scanning barcodes that I had pre-printed. The scanner that I was using in this example was just a USB wireless scanner, inputting to the page running on the emulator.
Cheers
Lachlan
Filed under: Warehouse management
organicax: Warehouse mobile device text colors some additional notes on setup Blog bot DAX Blogs 0 25.03.2016 12:11
organicax: Overview of editing the CSS style sheet for the warehouse mobile device Blog bot DAX Blogs 0 24.03.2016 22:12
organicax: Setting up the warehouse mobile device portal for a second company Blog bot DAX Blogs 0 09.03.2016 03:28
DynamicsAxSCM: Warehouse Mobile Device Portal Architecture Blog bot DAX Blogs 0 03.03.2015 19:11
DynamicsAxSCM: Warehouse Mobile Device Portal Blog bot DAX Blogs 0 23.02.2015 22:12
Часовой пояс GMT +3, время: 21:03.
