Старый 09.03.2016, 03:28   #1
organicax: Setting up the warehouse mobile device portal for a second company
Источник: http://organicax.com/2016/03/08/sett...econd-company/
In a previous post we had a look at the install process for creating a new warehouse mobile device portal. If you have multiple companies that you use with advanced warehouse then you will need to install another portal.
Here is a quick walkthrough in AX2012 R3 CU9.
While I was using CU9 in this example it’s the same for R3 through to CU10.
Cheers
Lachlan
Filed under: Warehouse management
DynamicsAxSCM: Creating Custom Solutions with the Warehouse Mobile Device Portal Blog bot DAX Blogs 0 13.03.2015 16:11
DynamicsAxSCM: Warehouse Mobile Device Portal Architecture Blog bot DAX Blogs 0 03.03.2015 19:11
DynamicsAxSCM: Warehouse Mobile Device Portal Blog bot DAX Blogs 0 23.02.2015 22:12
Kashperuk Ivan: Tip: Connecting the Warehouse management device portal to a different company or partition in Dynamics AX Blog bot DAX Blogs 0 03.12.2014 19:11
DynamicsAxSCM: Which devices can you use for Warehouse Mobile Device Portal? Blog bot DAX Blogs 0 19.07.2014 01:13
Часовой пояс GMT +3, время: 14:33.
