Старый 02.04.2014, 21:12   #1
emeadaxsupport: Installing individual application hotfixes using CU7 installer
Источник: http://blogs.msdn.com/b/axsupport/ar...tallation.aspx
I noticed that not everybody is aware that we can now install application updates (or a subset of them) using the advanced installation option in the CU7 installer. I wanted to demonstrate how you can do it. I hope it can help those who want to update specific bits without upgrading the whole application.
1. Run the axupdate.exe and install the components (it's a prerequisite to use the Advanced installation option)
2. Reinitialize the model store (read mode details)
  • On the Start menu, point to All Programs, point to Administrative Tools, and then click Microsoft Dynamics AX Management Shell.
  • At the Windows PowerShell command prompt, PS C:\>, type Initialize-AXModelStore, and then press ENTER.
3. Restart the axupdate.exe select Database and then Advanced installation
Now you can select the modules to update or specific hotfixes.
For any hotfix, the details pane displays the title of the hotfix, the model and any updates that are included.
See also
emeadaxsupport: Violation of PRIMARY KEY constraint 'PK_ModelElementData_ElementHandle' error installing some hotfixes on Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 0 08.01.2014 22:13
axsa: Microsoft Dynamics AX 2012 Data Import/Export Framework standalone version for AX 2012 R2 without installing full CU7 Blog bot DAX Blogs 0 04.12.2013 04:13
emeadaxsupport: AX Content: How to install CU7 for Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 0 12.11.2013 01:12
emeadaxsupport: After installing application Hotfix released on KB #2786631, it is not possible to cancel Invoice in Invoice approval journal on AX 2009 SP1 RU6 or higher Blog bot DAX Blogs 0 22.08.2013 14:11
emeadaxsupport: Role Center is no longer showing up after installing an Application Roll-Up package Blog bot DAX Blogs 0 08.06.2010 19:05
Часовой пояс GMT +3, время: 13:15.
