Старый 22.08.2013, 14:11   #1
emeadaxsupport: After installing application Hotfix released on KB #2786631, it is not possible to cancel Invoice in Invoice approval journal on AX 2009 SP1 RU6 or higher
Источник: http://blogs.msdn.com/b/axsupport/ar...or-higher.aspx
Issue description:
After installing application Hotfix released on KB #2786631, it is not possible to cancel Invoice in Invoice approval journal on AX 2009 SP1 RU6 kernel/application build #5.0.1500.3761 or higher, it is no more possible to make an annulment of a posted invoice register in Approval journal.
You get an error message stating that Vendor account XXXX does not exist.
Workaround description:
The failure is caused by code pattern in \Classes\LedgerJournalCheckPost\postTrans in above mentioned application hotfix as shown below:
    if (!ledgerJournalTransUpdate)
         ledgerJournalTransUpdate = ledgerJournalTransUpdateAmountIncl;
Change code as described below, save and compile:
    // Workaround to ensure we have the correct TransUpdate type
         if (ledgerJournalTable.JournalType == LedgerJournalType::Approval
         && _ledgerJournalTrans.AccountType == LedgerJournalACType::Ledger
         && _isOffset)
                      ledgerJournalTransUpdate = LedgerJournalTransUpdate::construct(_ledgerJournalTrans);
        else
Disclaimer:
This programming example is for illustration purposes only. Microsoft disclaims all warranties and conditions with regard to use of the programming example for other purposes. Microsoft shall not, at any time, be liable for any special, direct, indirect or consequential damages, whether in an action of contract, negligence or other action arising out of or in connection with the use or performance of the programming example. Nothing herein should be construed as constituting any kind of warranty.
emeadaxsupport: Dynamics AX 2009 - A negative receipt is not allowed on a Project PO - How to address this situation Blog bot DAX Blogs 0 15.03.2013 17:11
emeadaxsupport: Microsoft BizTalK Server 2010 passes compatibility testing with Microsoft Dynamics AX 2009 SP1 Blog bot DAX Blogs 0 30.09.2011 01:19
emeadaxsupport: Microsoft Dynamincs AX 2009 Workflow: Notification message does not contain PO number Blog bot DAX Blogs 0 22.09.2011 14:11
emeadaxsupport: Debugging non-interactive X++ code in Dynamics AX 2009 when running on Windows Server 2008 Blog bot DAX Blogs 0 23.09.2009 13:05
Часовой пояс GMT +3, время: 17:49.
