#1 |
mfp: AX 2012 Meta Model
Источник: http://blogs.msdn.com/b/mfp/archive/...eta-model.aspx
============== Like previous releases Microsoft Dynamics AX 2012 provides a model driven development platform. It enables us developers to create a business application using predefined types of building blocks (aka. concepts) – each targeted a specific purpose. To be an effective X++ developer you need to know the building blocks and how they relate. What is new in the meta model for AX 2012? Quite a lot – here is a short summary:
The diagram below shows the most common relationships between concepts. Each arrow should be read as “using”. For example:
I have printed the below diagram, and pinned it to a wall in my office. It serves me as a reference when I navigate the new areas of AX 2012. I hope it can do the same for you. Click the image for a larger version You might also want to look at the meta model for AX 4 ============== Источник: http://blogs.msdn.com/b/mfp/archive/...eta-model.aspx
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
