Старый 25.10.2017, 10:52   #4
trud is offline
trud
1,039 / 1635 (57) ++++++++
все секунды на 4-5 замирает и ждет пока в правой части формы обновятся поля.
Кстати торможение может и от версии браузера зависеть. вот на коннекте народ пишет что в IE тормозит, а в Chrome все нормально
In our particular case, 11 fields were added to the grid on form CustTable using form extension. As result, we get troubles with performance (around 4-8 seconds to change the line on the grid). And what is interesting - even if we simply make this fields not visible, performance becomes better.
After investigation on the server side, we found out, that server is busy for less than 1 second, and all other time, there is a freeze on the client side. You can find network diagrams on the picture below.
Also, we found out that trouble is only in IE browser because in Chrome this form works fine (1.5 -2 seconds to change the line on the grid).
d365o, grid
atinkerersnotebook: Self Service Reporting For Users – Part 2: Use Edit in Grid as your Reporting Worksheet Blog bot DAX Blogs 0 06.10.2015 15:11
tlefor: Dynamics AX 2012: How Wide is my Grid Column? Blog bot DAX Blogs 0 28.10.2013 10:11
axaptapedia: Filter-by-Grid Blog bot DAX Blogs 2 30.05.2012 13:39
Dynamics AX: DAX 4.0 Filter by Grid [Update] Blog bot DAX Blogs 0 27.04.2007 17:10
Advanced programming: Grid data and view manipulations batiskaf_new DAX: Программирование 15 21.06.2006 11:44
Часовой пояс GMT +3, время: 11:56.
