Старый 27.04.2007, 17:10   #1
Dynamics AX: DAX 4.0 Filter by Grid [Update]
Источник: http://dynamics-ax.blogspot.com/2007...id-update.html
Well take a look at this:
"bskiles has left a new comment on your post "Filter by Grid in DAX 4.0":
I [bskiles] was trying to figure out how to turn the "Filter by Grid" on in code, and I figured it out. Call the .task method on the form with a parameter of 2855 after the grid is selected. Anything that extends FormRun can make the call to .task(2855). Unfortunately, I can't trace it back up to FormRun since that's a system object.
I'm still interested in learning how it actually works so that I can set it up as a user setting per grid. "
It's a comment from my blog entry here: Filter by Grid - Older Post bskiles took the time and was able to find how to actually call the Filter by Grid from code! Very nice work! It's strange that it's such a hidden event / call? Anyway just wanted to report this find, thanks bskiles!
Find a job at: www.DynamicsAXJobs.comFind a job at: DynamicsAXJobs.com, also post a job for only $99.00!
hariprasadp: Grid Filter while open a form in Dynamics AX Blog bot DAX Blogs 0 07.05.2008 15:05
Dianne Siebold: Update on the Dynamics AX SDK Team kashperuk DAX Blogs 1 16.10.2007 08:23
Часовой пояс GMT +3, время: 19:42.
