Старый 11.06.2015, 23:51   #8
Aquarius is offline
Aquarius
Добрый вечер,
Ax 2009 SP1 Ru5.MS SQL2008, VS 2008
планируем настраивать Sql Server Report Service.я предварительно просматривала описание настроек для разворачивания SSRS. дошла до пункта Deploying Microsoft Dynamics AX Reports .
В руководстве написано "The reporting extensions must be installed on a dedicated server where no other Microsoft Dynamics AX components are installed. "
Подскажите пожалуйста, что значит фраза "no other Microsoft Dynamics AX components are installed" ? какие Microsoft Dynamics AX components? нужно ли следовать этому совету?
этот текст скопирован из этого отрывка :
"Deploying Microsoft Dynamics AX Reports
Microsoft Dynamics AX includes many preconfigured reports that must be deployed to Reporting Services.
Install Reporting Extensions
Follow these steps to install the reporting extensions. If other Microsoft Dynamics AX components are being installed at the same time, the installation screens will vary based on the components being installed.
NOTE: The reporting extensions must be able to connect to the base installation
of Microsoft Dynamics AX (database, application files, and AOS) that has had
the initialization checklist completed. The reporting extensions must be installed
installed.
1. Start the Microsoft Dynamics AX Setup wizard.
2. On the Select installation type page, select Custom installation.
Click Next.
3. On the Select components page, select the Reporting extensions check box. Click Next.
4. On the Install files page, specify where to install the reporting extensions .DLL files. Either accept the default location or click Browse to select a different location. Click Next.
5. On the .NET Business Connector: Select a display language page, select the language for the Microsoft Dynamics AX Client. Click Next.
6. On the .NET Business Connector: Connect to AOS instance page, enter the name of the AOS server. Click Next.
7. On the .NET Business Connector proxy account information 8. page, enter the password for the .NET Business Connector proxy account. Click Next.
9. On the Reporting extensions: Select a Reporting Services instance page, select the instance of Reporting Services to use with Microsoft Dynamics AX. "
Последний раз редактировалось Aquarius; 12.06.2015 в 00:04.
msdax: Installing Sql Server 2008 and Dynamics AX 2009 on Windows Server 2008 x64 « Dynamics AX Blog bot DAX Blogs 0 04.04.2011 12:11
dynamics-ax: Dr. BI Tip: SQL Server 2008 R2 & Report Builder 3 for AX 2009 Blog bot DAX Blogs 0 31.03.2011 18:11
настройка MS SQL Server 2008 под AX 2009 propeller DAX: Администрирование 4 05.07.2010 10:43
emeadaxsupport: Debugging Microsoft Dynamics AX 2009 SSRS reports with Microsoft Visual Studio 2008 Blog bot DAX Blogs 0 26.07.2009 15:07
mfp: Upgrading to Microsoft Dynamics AX 4.0 and Microsoft Dynamics AX 2009 @ Convergence 2008 Blog bot DAX Blogs 0 22.02.2008 17:37
Часовой пояс GMT +3, время: 04:44.
