Старый 26.06.2012, 23:12   #1
emeadaxsupport: Unable to deploy AX 2012 Reporting Extensions on SQL Server 2012 Reporting Server
Источник: http://blogs.msdn.com/b/axsupport/ar...ng-server.aspx
We came across an issue where we had:
- a new server that never had Microsoft SQL Server 2008/2008 R2 or SQL Server 2012 ever installed
- we were using a Microsoft Dynamics AX 2012 Installation files from a network share to install the AX Reporting Extensions
- In the updates folder inside the installation share, we had a folder containing the extracted contents of SQL Server 2012 Compatibility hotfix
However the Reporting Extensions fail to install, and we get the following error in the DynamicsSetupLog.txt file:
An error occurred during setup of Reporting Services extensions.
Reason: Could not load file or assembly 'Microsoft.SqlServer.BatchParser, Version=10.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91' or one of its dependencies. The system cannot find the file specified.
System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.SqlServer.BatchParser, Version=10.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91' or one of its dependencies. The system cannot find the file specified.
File name: 'Microsoft.SqlServer.BatchParser, Version=10.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91'
To resolve this issue we downloaded and installed the following two components from the SQL Server 2008 R2 Feature Pack :
(1) Microsoft® SQL Server® 2008 R2 Shared Management Objects (SMO)
(2) Microsoft® System CLR Types for SQL Server® 2008 R2 (required package for SMO)
Both of this you can search and download from: Microsoft® SQL Server® 2008 R2 Feature Pack - http://www.microsoft.com/en-us/downl....aspx?id=16978
--author: Egil Ivar Skjold
emeadaxsupport: Microsoft Dynamics AX 2012 Reporting: How to run reports that executes longer than 10 minutes Blog bot DAX Blogs 0 25.01.2012 10:11
emeadaxsupport: Opening a Report on AX 2012 raises infolog error: The default Report Server Configuration ID could not be found in the SRSServers table. Blog bot DAX Blogs 0 02.12.2011 00:13
emeadaxsupport: Unable to deploy AX 2012 default SRS reports Blog bot DAX Blogs 1 13.10.2011 22:05
emeadaxsupport: Integrating Microsoft Dynamics AX 2012 with Microsoft BizTalk Server 2010 Blog bot DAX Blogs 0 25.08.2011 19:11
emeadaxsupport: Some reports from Reporting extensions can raise error when running on SQL 2008 R2 Blog bot DAX Blogs 0 18.03.2011 20:11
Часовой пояс GMT +3, время: 01:35.
