Старый 25.01.2012, 10:11   #1
emeadaxsupport: Microsoft Dynamics AX 2012 Reporting: How to run reports that executes longer than 10 minutes
Источник: http://blogs.msdn.com/b/axsupport/ar...0-minutes.aspx
Sometime ago we run into problem when reports that executes longer than 10 minutes are running into timeout error. To overcome this problem:
- For reports printed in batch job you need to install kernel hotfix KB 2642168 - the KB article is still not published on Partner source but you should be able to get hotfix through Microsoft Dynamics AX Support team
- For reports printed on screen. You need to:
  1. Open configuration:
    1. If a configuration file has been created for reporting services according to http://technet.microsoft.com/en-us/l.../hh389774.aspx (make sure it’s in the right folder!), open that file in Microsoft Dynamics Ax Configuration Utility
    2. If no such configuration file has been created, open the Microsoft Dynamics Ax Configuration Utility configuration.
  2. On the Connection tab, select Configure Services
  3. Select the service binding to modify under the Bindings node (QueryServiceEndpoint in this case) and tweak the SendTimeout or ReceiveTimeout parameter as necessary. SendTimeout is the one that needs tweaking:
  4. Restart SQL Reporting Services and Microsoft Dynamics Ax Client
emeadaxsupport: Microsoft Dynamics AX 2012 Enterprise Portal: How to provider access for user to be able to only Personalize Page on SharePoint 2010 Blog bot DAX Blogs 0 13.12.2011 22:11
emeadaxsupport: Microsoft Dynamics AX 2012 Reporting Services – Scale-out deployments Blog bot DAX Blogs 0 28.11.2011 00:14
DynamicsAxSCM: Operational Sites in Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 25.05.2011 19:11
Часовой пояс GMT +3, время: 11:21.
