Старый 29.10.2019, 14:05   #1
Ion is offline
Ion
Unable to disqualify a lead in unified interface
Добрый день!
Сталкивался кто-то с проблемой в unified interface: не работает кнопка 'Disqualify' на форме лида. В консоле вижу следующую ошибку:
Код:
<Menu Id="lead|NoRelationship|Global|Mscrm.Form.lead.DM.DisqualifyLeadAs">
    <parsererror xmlns="http://www.w3.org/1999/xhtml" style="display: block; white-space: pre; border: 2px solid #c77; padding: 0 1em 0 1em; margin: 1em; background-color: #fdd; color: black">
        <h3>This page contains the following errors:</h3>
        <div style="font-family:monospace;font-size:12px">error on line 1 at column 1427: EntityRef: expecting ';'
</div>
        <h3>Below is a rendering of the page up to the first error.</h3>
    </parsererror>
    <MenuSection Id="lead|NoRelationship|Form|Mscrm.Form.lead.DM.DisqualifyLeadAs.DisqualifyLeadAs" Sequence="10" DisplayMode="Menu16">
        <Controls Id="lead|NoRelationship|Form|Mscrm.Form.lead.DM.DisqualifyLeadAs.DisqualifyLeadAs.Controls">
            <Button Id="lead|NoRelationship|Form|Mscrm.Form.lead.DM.DisqualifyLeadAs.DisqualifyLeadAs.Controls.909520000|909520000" Command="lead|NoRelationship|Global|Mscrm.Form.lead.DisqualifyAs" Sequence="10" ToolTipDescription="Administrative Inquiry" Alt="Administrative Inquiry" LabelText="Administrative Inquiry" />
            <Button Id="lead|NoRelationship|Form|Mscrm.Form.lead.DM.DisqualifyLeadAs.DisqualifyLeadAs.Controls.5|5" Command="lead|NoRelationship|Global|Mscrm.Form.lead.DisqualifyAs" Sequence="20" ToolTipDescription="Cannot Contact" Alt="Cannot Contact" LabelText="Cannot Contact" />
            <Button Id="lead|NoRelationship|Form|Mscrm.Form.lead.DM.DisqualifyLeadAs.DisqualifyLeadAs.Controls.909520008|909520008" Command="lead|NoRelationship|Global|Mscrm.Form.lead.DisqualifyAs" Sequence="30" ToolTipDescription="Company No Longer Exists" Alt="Company No Longer Exists" LabelText="Company No Longer Exists" />
        </Controls>
    </MenuSection>
</Menu>
Контрол полностью стандартный, никаких кастомизаций не делали.
Старый 29.10.2019, 18:24   #2
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
3,243 / 896 (36) +++++++
Проверил свой инстанс, у меня все сработало без проблем. У меня клауд, вот версия:
Microsoft Dynamics 365
2019 release wave 2 enabled
Server version: 9.1.0000.9439
Client version: 1.3.2371-191024-232557
Какая версия у вас?
Старый 29.10.2019, 18:36   #3
Ion is offline
Ion
Какая версия у вас?
Вот моя, тоже клауд, странно что не работает. Открою тикет
Server version: 9.1.0000.9827
Client version: 1.3.2399-191022-002238
Старый 29.10.2019, 19:32   #4
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
У вас версия поновее. Возможно с этим обновлением и проблема накатилась.
Старый 18.11.2019, 17:51   #5
Ion is offline
Ion
Проблема была и есть)) И кроется она в ...'&'))) Да, этот символ ламает напрочь кнопку
Старый 18.11.2019, 18:11   #6
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
Сообщение от Ion Посмотреть сообщение
А поподробнее? Правильно ли понимаю, что в метке statuscode присутствует & - функционал ламается?
Старый 18.11.2019, 20:29   #7
Ion is offline
Ion
В моей версии ломался, но на днях MS выпустил обновления и там есть фикс этой баги. Это то что мне сегодня написали с саппорта
stoneridgesoftware: Updates to Forms in Dynamics 365 Customer Engagement Unified Interface Blog bot Dynamics CRM: Blogs 0 24.08.2019 00:22
crmtipoftheday: Tip #1197: Unified Interface lookup changes Blog bot Dynamics CRM: Blogs 0 22.11.2018 17:13
survivingcrm: Unified Interface Form Design Notes Blog bot Dynamics CRM: Blogs 0 11.07.2018 02:46
survivingcrm: Card Forms and List Views in Unified Interface Blog bot Dynamics CRM: Blogs 0 05.07.2018 00:45
survivingcrm: The Long Road to Unified Interface in Dynamics 365 Blog bot Dynamics CRM: Blogs 0 04.07.2017 12:11
Часовой пояс GMT +3, время: 10:56.
