Старый 15.08.2019, 05:12   #1
crmtipoftheday: Tip #1295: Quickly search for multiple records in advanced find
Источник: https://crmtipoftheday.com/1295/quic...advanced-find/
If you want to quickly find multiple records in advanced find, you can type in semicolon-separated text values into your filter.
This can be a huge time saver, as you can copy/paste the string in, and assuming they are legitimate records, each value will resolve.
This is also helpful for testing a set of records after a data update.
Note — there is a limit to the number of values you can enter. Based on testing, it is somewhere around 65.
Thanks to Edgar Chan for this tip. Got any tips? Send them to jar@crmtipoftheday.com.
crmtipoftheday: Tip #1060: Quickly create vector/SVG images for Dynamics 365 Blog bot Dynamics CRM: Blogs 0 24.01.2018 22:11
crmtipoftheday: Tip #1018: Automatically create Dynamics 365 records from Social Engagement Blog bot Dynamics CRM: Blogs 0 08.11.2017 18:11
stoneridgesoftware: Relevance Search Dynamics 365 for Sales (CRM) Blog bot Dynamics CRM: Blogs 0 22.04.2017 02:26
atinkerersnotebook: Use Filter By Selection To Quickly Find Common Records Blog bot DAX Blogs 0 12.03.2014 14:11
Dynamics CRM Tools: Advanced Find Search: Where is this damn N:N relationship??? Blog bot Dynamics CRM: Blogs 1 16.12.2010 12:33
Часовой пояс GMT +3, время: 09:36.
