Старый 26.07.2019, 18:12   #1
a33ik: SSRS display in header value from dataset/tablix
Источник: http://daxonline.org/1651-ssrs-displ...et-tablix.html
Create textbox or refer to existing on with expression to display data from dataset (Right click and Text Box Properties). It could be even hidden field.
Create following expression to refer value from text box: =ReportItems!TextBoxName.Value
a33ik: SSRS display static row as header at each page Blog bot DAX Blogs 0 26.07.2019 18:12
kamalblogs: Error: SSRS/EP error when the return type in display method is incorrect – Dynamics AX 2012 Blog bot DAX Blogs 0 11.10.2013 12:11
dynamics-ax: Expert SSRS with AX Tip from Michael Stashwick Blog bot DAX Blogs 0 14.01.2011 05:18
Часовой пояс GMT +3, время: 04:11.
