Старый 08.07.2019, 18:12   #1
axaptacorner: How to find SQL query out of the AOT query:
Источник: http://axaptacorner.blogspot.com/2019/07/blog-post.html
static void AOTQuery(Args _args)
QueryRun queryRun;
queryRun = new QueryRun(queryStr(QueryName));//add any name of query here in place of QueryName
info(queryRun.query().toString());
emeadaxsupport: How to perform a data center change (change of the physical location) where a SQL server 2008 R 2 cluster installation and MS Dynamics AX 4.0 is involved? Blog bot DAX Blogs 0 21.06.2014 19:19
axaptacorner: How to create Query in AX 2012 through X ++ code Blog bot DAX Blogs 0 20.09.2012 17:11
daxdilip: Tip - How to avoid Overriding of SQL Indexes from AX when a Full Synchronization is done Blog bot DAX Blogs 0 17.05.2011 11:11
daxdilip: Tip - How to avoid Overriding of SQL Indexes from AX when a Full Synchronization is done Blog bot DAX Blogs 0 12.05.2011 08:11
dynamicsaxtraining: How to copy dynamic links from one query to another Blog bot DAX Blogs 0 09.12.2010 02:13
Часовой пояс GMT +3, время: 11:39.
