Старый 28.03.2019, 03:33   #1
alirazazaidi: How to copy financial dimension form one object to other. Dynamics 365 For finance and operations
Источник: https://www.tech.alirazazaidi.com/ho...nd-operations/
Hi all, In some cases we can need to copy  financial dimension from one object to  other for example Customer to Sales order or Vendor to purchase order.
In Ax 2012  it little easy. But in D365 For finance and operations, it is little bit tricky.
I did this with following code snippet.  With the help of out of box. LedgerDimensonDefaultFacade class i used the merge default dimension method and passed same table dimension in form and to dimension.
Result is interesting.
 salestable.DefaultDimension= LedgerDimensionDefaultFacade::serviceMergeDefaultDimensions(CustTable.DefaultDimension,CustTable.DefaultDimension);
powerobjects: How to Integrate Power BI with Dynamics 365 for Finance and Operations Blog bot Dynamics CRM: Blogs 0 26.06.2018 01:23
jaestevan: Microsoft Dynamics 365 for Operations Blog bot DAX Blogs 0 02.11.2016 01:11
Часовой пояс GMT +3, время: 11:52.
