Старый 02.02.2019, 02:51   #1
sinedax: 8.1.3 Platform Update 23 Installation Issue - Dynamics 365 for Finance & Operations LBD
Источник: http://sinedax.blogspot.com/2019/02/...tallation.html
Hi all,
in the last days I tried to install the 8.1.3 Platform Update 23 version on my F&O LBD Environment but I raised some error.
Really thank you to Mohamed Zaki and Renaud Paquay for helping me to address the resolution.
AOS Application Error:
Application: AXBootstrapper.exe
Framework Version: v4.0.30319
Description: The application requested process termination through System.Environment.FailFast(string message).
Message: RunAsync failed due to an unhandled exception causing the host process to crash: System.Management.Automation.RuntimeException: Exception calling "GetTypes" with "0" argument(s): "Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information." ---> System.Management.Automation.MethodInvocationException: Exception calling "GetTypes" with "0" argument(s): "Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information." ---> System.Reflection.ReflectionTypeLoadException: Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information.
at System.Reflection.RuntimeModule.GetTypes(RuntimeModule module)
Reason:
AxBootStrapper is trying to load the netstandard.dll assembly from the GAC.
Resolution:
You need to install the netstandard.dll to your GAC on all AOSs.
For each AOS, go through C:\Program Files (x86)\Microsoft SDKs\Windows\v8.1A\bin\NETFX 4.5.1\ and run the following CMD command:
gacutil.exe -i "
You can find the DLL to the Agent path \\....WP\EnvName\StandaloneSetup-xxxxxxx\Apps\AOS\AXServiceApp\AXSF\Code\bin\
I guess the hotfix coming soon!
Till soon!
sinedax: Deploy SSRS Reports Manually - Dynamics 365 for Finance & Operations On Premises Installation Blog bot DAX Blogs 0 02.01.2018 14:12
instructorbrandon: Importance of Platform Update Methodology in Dynamics 365 for Operations Blog bot DAX Blogs 0 16.10.2017 10:11
stoneridgesoftware: Microsoft has Released the 4th Platform Update for Dynamics 365 for Operations Blog bot DAX Blogs 0 12.04.2017 02:30
Microsoft Dynamics CRM Team Blog: Update Rollup 5 for Microsoft Dynamics CRM 2011 Blog bot Dynamics CRM: Blogs 2 27.10.2011 17:11
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2009 SP1 Blog bot Dynamics CRM: Blogs 0 11.06.2010 16:33
Часовой пояс GMT +3, время: 02:59.
