Старый 23.01.2019, 11:11   #1
ax.docentric: Comment on Append Terms and Conditions to printed Purchase orders or Invoices in D365FO by Jure Leskovec
Источник: https://ax.docentric.com/append-term...o/#comment-642
Hi Bablu,This can be very easily achieved by simply putting your SUB DOCUMENT tagging element that represents Terms & Conditions in a new document section.Note that MS Word allows you to have multiple document sections in a single document, with each section having its own page settings and different set of headers and footers.In order to fix your problem you simple need to insert a Section Break before the SUB DOCUMENT tagging element.You can read more about how to work with document sections here:https://support.office.com/en-us/art...e77ca8ea1f3You will also need to un-link the new section so that it will not inherit headers and footers from the previous section.Please confirm if this helped.Best regards,Jure Leskovec
ax.docentric: Comment on Append Terms and Conditions to printed Purchase orders or Invoices in D365FO by bablu Blog bot DAX Blogs 0 23.01.2019 11:11
ax.docentric: Comment on Append Terms and Conditions to printed Purchase orders or Invoices in D365FO by Ana Blog bot DAX Blogs 0 23.01.2019 11:11
dynamics-coe: Dynamics AX Export/Import Framework for Vendor balance migration Blog bot DAX Blogs 0 22.05.2013 20:13
Часовой пояс GMT +3, время: 11:38.
