Старый 22.01.2019, 17:11   #1
goshoom: Event handler for multiple events
Источник: http://dev.goshoom.net/en/2019/01/ev...ltiple-events/
I’m not sure that everybody is aware that a single event handler method (in Dynamics 365 for Finance and Operations) can be decorated with several event handler attributes.
For example, a common method can handle both inserts and updates.
[ DataEventHandler(tableStr(MyTable), DataEventType::Inserted), DataEventHandler(tableStr(MyTable), DataEventType::Updated)]public static void myHandler(Common _sender, DataEventArgs _e)
Or it can handle similar events from different sources, such as different tables:
[ DataEventHandler(tableStr(InventItemSalesSetup), DataEventType::Inserting), DataEventHandler(tableStr(InventItemPurchSetup), DataEventType::Inserting), DataEventHandler(tableStr(InventItemInventSetup), DataEventType::Inserting)]public static void myHandler(Common sender, DataEventArgs e){ InventItemOrderSetupMap inventSetup = sender; ...}
If you want to run the same logic, simply using the same method makes good sense.
stoneridgesoftware: Event Handler Methods in Dynamics 365 for Operations (AX7) Blog bot DAX Blogs 0 22.12.2016 21:11
Navigate Into Success: Trick: Subscribing to any Control Add-in event through pure C/AL Blog bot Dynamics CRM: Blogs 0 04.08.2014 11:00
Часовой пояс GMT +3, время: 07:58.
