Старый 05.12.2018, 02:27   #1
alirazazaidi: Table method extension and grid field mapping Dynamics 365 for finance and operations
Источник: https://www.tech.alirazazaidi.com/ta...nd-operations/
Hi all, here is small tip, I learned today, so document it
I need a custom method in table extension. And then this method need to call in field mapping inside Grid. Interesting it is amazing easy.
So like other extensions. You have to create a class add a attribute and make in static class show it will extension of certain table. And now create a method Suppose I need extension for PurchRFQScoring table
[ExtensionOf(tableStr(PurchRFQScoring))]
public static class PurchRFQScoring_Extension
[SysClientCacheDataMethodAttribute(true)]  //This attribute will cache your display method.
public static display Name ScoringName(PurchRFQScoring _this)
return PurchRFQScoringRFQCaseCriteria::find(_this.ScoringRFQCaseCriteria).name;
Now compile solution. And open the grid and from field mapping, set table In source. And in field you have to add method with class reference like
PurchRFQScoring_Extension::ScoringName
powerobjects: Electronic Reporting in Dynamics 365 for Finance and Operations Blog bot DAX Blogs 0 14.02.2018 03:28
Часовой пояс GMT +3, время: 21:27.
