Старый 23.08.2018, 21:12   #1
dynamicsaxse: Dynamics AX 2012 R3 Enterprise Portal Setup with Auth0
Источник: https://blogs.technet.microsoft.com/...up-with-auth0/
This article will assist you with the setup of an external Enterprise portal site using Auth0 user authentication mechanism.
Start by downloading the required KB 4133646 for Dynamics AX2012 R3.
Secondly, download the PDF file Dynamics-AX-2012-R3-Enterprise-Portal-Setup-with-Auth0. This document will describe all the steps required to setup your external Enterprise portal site using Auth0.
dynamicsaxse: July 2017 release – Dynamics AX 2012 R3 Blog bot DAX Blogs 0 25.07.2017 20:11
emeadaxsupport: AX Performance Troubleshooting Checklist Part 2 Blog bot DAX Blogs 0 09.09.2014 16:11
DAX: A Shift to Effective Demand Forecasting With Microsoft Dynamics AX 2012 R3 Blog bot DAX Blogs 0 16.11.2013 02:13
Dynamics AX на Convergence 2012 Blog bot Microsoft и системы Microsoft Dynamics 0 13.01.2012 10:52
Часовой пояс GMT +3, время: 05:48.
