Старый 13.04.2018, 09:11   #1
dynamicsnavax: Add a new starting worker for workflow hierarchy approval #MSDyn365FO
Источник: http://dynamicsnavax.blogspot.com/20...-workflow.html
This is very simple but not too obvious. There are times when you want to start the hierarchy approval with a specific worker and then have it traverse up the hierarchy.
See screenshot below screenshot of some of the options. You may want to add something different to what is already available.
The way it works is, it uses certain EDTs on the table.
So, all you need to do is add a field that extends one of these EDTs. Or just subscribe to the delegate to add another EDT.
Below is some code that could give inspiration.
dynamicsnavax: Add Spending/Approval limit to Purchase Order Workflow #MSDyn365FO Blog bot DAX Blogs 0 01.04.2018 09:12
dynamicsnavax: Workflow hierarchy limit checker for D365FO Blog bot DAX Blogs 0 26.12.2017 07:12
Navigate Into Success: Deploying control add-ins during development in NAV 2016 Blog bot Dynamics CRM: Blogs 0 13.11.2015 10:00
atinkerersnotebook: Using the Dynamics AX Excel Add-In Blog bot DAX Blogs 1 25.09.2013 07:11
NAV Team: Let NAV Speak (with a Simple and Useful Client Add-in) Blog bot Dynamics CRM: Blogs 0 10.07.2010 02:37
Часовой пояс GMT +3, время: 11:54.
