Старый 12.02.2018, 19:11   #1
axinthefield: Did you check Resource Governor settings before starting your load testing?
Источник: https://blogs.msdn.microsoft.com/axi...-load-testing/
Dynamics AX 365 For Operations is leveraging the Resource Governor available in SQL Server. But before we dive in, let's first get the basics. What is the Resource Governor? In short the Resource Governor enables you to specify limits on the amount of CPU, physical IO, and memory that incoming application requests can use. To...
d365o
yetanotherdynamicsaxblog: Use Azure Automation to start and stop your VMs on a schedule Blog bot DAX Blogs 0 23.10.2017 00:14
axinthefield: Benchmark your Dynamics AX solution with Load Testing Blog bot DAX Blogs 0 17.10.2013 04:36
axinthefield: Top 10 issues discovered from Dynamics AX Health Check Blog bot DAX Blogs 0 27.06.2013 19:11
axinthefield: Are your AX 2012 AOS servers load balancing? Blog bot DAX Blogs 0 02.05.2012 13:11
Dynamics AX: Performance Load Testing for Dynamics AX [Soon!] Blog bot DAX Blogs 0 19.03.2007 08:05
Часовой пояс GMT +3, время: 08:50.
