Старый 27.12.2017, 18:11   #1
emeadaxsupport: Management Reporter 2012 compatibility with Microsoft SQL Server 2017
Источник: https://blogs.msdn.microsoft.com/axs...l-server-2017/
Management Reporter 2012 is currently not compatible with Microsoft SQL Server 2017. When you try to install Management Reporter 2012 on SQL Server 2017, you receive this error: The database deployment failed. Additional information: Microsoft.SqlServer.Dac.DacServicesException: Could not deploy package. —> Microsoft.Data.Tools.Schema.Sql.Deployment.DeploymentFailedException: Unable to connect to target server.   There are no plans to support Microsoft... Read more
emeadaxsupport: AX Performance - Analyzing key SQL Server configuration and database settings Blog bot DAX Blogs 0 28.09.2015 14:11
emeadaxsupport: Translated User Help on TechNet and downloadable New Features lists available! Blog bot DAX Blogs 0 31.01.2013 05:11
emeadaxsupport: Unable to deploy AX 2012 Reporting Extensions on SQL Server 2012 Reporting Server Blog bot DAX Blogs 0 26.06.2012 23:12
Microsoft Dynamics CRM Team Blog: Building a Self-Contained Virtual CRM Development Server Blog bot Dynamics CRM: Blogs 0 05.05.2009 10:05
Часовой пояс GMT +3, время: 23:48.
