Старый 06.10.2017, 02:21   #1
stoneridgesoftware: How to use a Query Range Status on a Filterable Grid Field in Dynamics AX
Источник: https://stoneridgesoftware.com/how-t...n-dynamics-ax/
I had a recent request to make a field filterable on a grid in Dynamics AX.
I checked the form control and saw that the field was coming directly from the datasource. So I checked the usual properties… Allow edit was no on the control and the datasource. Skip was no on both the control and the datasource. I noticed the auto declaration was no, so I wasn’t initially expecting it to be changed in the code.
A quick find for refnum in the code and I noticed the below change:
They used the range status of hidden to limit the ability to filter on the field. Cool! Something I’ve not used before and wanted to share!
atinkerersnotebook: Using Export To Excel in Dynamics AX to Create Reporting Data Sources Blog bot DAX Blogs 1 12.10.2013 01:13
Sample Design Patterns: Book Give-away: 'Microsoft Dynamics AX 2012 Security How-To' Blog bot DAX Blogs 0 13.12.2012 01:13
Часовой пояс GMT +3, время: 00:04.
