Старый 13.09.2017, 13:11   #1
sunilrakesh: Tree structure on a custom form  D365 Ops
Источник: https://community.dynamics.com/membe...f-ed7d20fadbd4
Today I came across to develop tree structure like parent asset having multiple child assets... for an custom form same like Asset form ->structure tab. For this follow below steps to achieve.
1. Create new class.
// This is a framework class. Customizing this class may cause problems with future upgrades to the software.
public class ImageListAppl_Unit extends ImageListAppl
void build()
super();
this.add(#ImageItem);
this.add(#ImageBOM);
<div class="paragraph" style="text-align:left;">void createStruct()
FormTreeItem formTreeStructure;
imageListAppl = new ImageListAppl_Unit();
structure.setImagelist(imageListAppl.imageList());
select assetTable where assetTable.ProjId == UnitTable.ProjId;
assetIdTop = assetTable.topMainAsset();
// This is not a threat because it is only adding additional asset numbers to the tree.
// BP Deviation Documented
formTreeStructure = new FormTreeItem(assetIdTop, imageListAppl.image(AssetTable::treeImage(assetIdTop)),-1,assetIdTop);
structure.delete(structure.getRoot());
this.buildComposedOf(assetIdTop,structure.addItem(0,FormTreeAdd::Sort,formTreeStructure));
buildStructure = false;
void buildComposedOf(AssetId _assetId,
int _treeHeader,
NoYes _list = NoYes::No)
FormTreeItem formTreeItem;
container childList;
AssetId childAssetId;
Counter childListLength;
Counter childIdx;
int node;
if (!_assetId)
return;
childList = AssetTable::childList(_assetId);
childListLength = conLen(childList);
for (childIdx = 1; childIdx
stoneridgesoftware: Creating a Default Lookup Form with Filter in Dynamics AX Blog bot DAX Blogs 0 29.07.2016 02:37
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
Часовой пояс GMT +3, время: 23:19.
