Старый 08.09.2017, 11:11   #1
gideonvos: IoT Health & Safety in Dynamics AX 7
Источник: https://gideonvos.wordpress.com/2016...s-ax-7-part-1/
This is a quick project I put together to explore using small-size IoT modules for practical work, say Health & Safety or Equipment monitoring and reporting. For this post I’ll use the super-compact Cactus Rev 2 which gives me multiple I/O ports with WiFi built-in via an ESP8266 and I will use that to transmit three sensor values to Dynamics AX 7 via ThingSpeak.
The Cactus Rev 2 module is an amazing little device that measures less than 4cm by 2cm and is half a centimeter thick. It can be powered via USB or RAW and runs off
gideonvos: Dynamics AX RFID using IoT Blog bot DAX Blogs 0 08.09.2017 11:11
ax-erp: Creating SSRS-Reports in Dynamics AX 2012 – What’s no longer possible in AX-reports Blog bot DAX Blogs 0 18.07.2012 12:11
dynamics-ax: Interview with Microsoft's Doug Kennedy & Kees Hertogh Blog bot DAX Blogs 0 14.06.2011 07:12
dynamics-ax: Official Details about Dynamics AX '6' released, including comments from Microsofts Kees Hertogh Blog bot DAX Blogs 0 11.01.2011 05:22
Часовой пояс GMT +3, время: 17:14.
