Старый 04.09.2017, 15:11   #1
Kashperuk Ivan: Development tutorial: insert_recordset using the Query class
Источник: http://kashperuk.blogspot.com/2017/0...recordset.html
IntroductionI am sure most of you are familiar with set-based X++ CUD operators: insert_recordset, update_recordset and delete_from. They allow performing database operations with a large number of records in a single roundtrip to the server, instead of a row-by-row type of operation, which depends on the number of rows being processed. As a result, they can provide a very significant boost in
Kashperuk Ivan: Development tutorial link: Extending the Warehouse management functionality after application seal Blog bot DAX Blogs 0 16.04.2017 02:31
Kashperuk Ivan: Development tutorial: SysExtension framework with SysExtensionIAttribute and an Instantiation strategy Blog bot DAX Blogs 0 01.04.2017 02:17
Kashperuk Ivan: Development tutorial: Platform improvements for handling X++ exceptions the right way Blog bot DAX Blogs 0 30.03.2017 14:11
Kashperuk Ivan: Development tutorial: SysExtension framework in factory methods where the constructor requires one or more arguments Blog bot DAX Blogs 4 19.03.2017 23:56
Kashperuk Ivan: Development tutorial: Extensible base enumerations in Microsoft Dynamics AX 7 Blog bot DAX Blogs 0 27.09.2016 00:19
Часовой пояс GMT +3, время: 01:07.
