Старый 04.07.2017, 16:01   #1
Morpheus is offline
Morpheus
Аватар для Morpheus
602 / 167 (7) ++++++
How to save SSRS report in .doc format by means of X++ (Dynamics AX 2012)?
The SSRS report viewer allows users to save the report as *.doc file. Unfortunately the enumeration SRSReportFileFormat does not contain any entry related to .doc format. It means that it is impossible to save the SSRS report in .doc format in Dynamics AX 2012 by standard means of SRS framework. So I would like to address this issue in the article.
The report viewer interacts with SSRS by means of a web service. To fulfil our task we should do the same...
Continue reading...
Последний раз редактировалось Morpheus; 04.07.2017 в 16:14.
emeadaxsupport: AX Performance Troubleshooting Checklist Part 1B [Application and AOS Configuration] Blog bot DAX Blogs 0 05.09.2014 21:11
dax-lessons: Save SSRS report to pdf that uses Controller classes [Dynamics AX 2012] Blog bot DAX Blogs 0 12.05.2012 01:11
Часовой пояс GMT +3, время: 05:00.
