Старый 13.04.2017, 18:11   #1
erconsult: Electronic Reporting (ER) Cookbook
Источник: http://erconsult.eu/blog/electronic-...g-er-cookbook/
The Electronic Reporting module in Dynamics 365 for Operations, previously known as General Electronic Reporting (GER) was one of the coolest application inventions in Dynamics AX7. Programmed apparently in my alma mater – the Dynamics development office in Moscow – this “ER” is a surprisingly powerful tool with an own in-built programming language for transformations. A consultant may configure any vendor payment format or any moderately complex GL export (such as the German GDPdU or French FEC) within days with literally no customizations, and test it in-place.
Over the last year, I implemented the British BACS18, the Swiss DTA, the Spanish SEPA sub-format and the North American ACH outbound payment format. While the AX wiki is a good start, the best way to learn the tool is practice. Below are some transformation code snippets that may help you along the steep learning curve.
Line counters
In the payment files, there are often line numbers. The ER element “Counter” is intended to be used, but it is incremented on every occurrence in the format. I.e. the counter has a global context, and the same count may not be used more than once in a row.
A total of records in a footer section is a special case: you may enumerate the lines with a Counter, then use a function of the Group by type over the data source to get a total count.
With 2 concurrent counters you have no other choice but to use the [real numeric] use the journal line number, and convert it into an integer:
NUMBERFORMAT(VALUE(model.Payments.PaymentIdentifications.SourceBusinessEntityDescription), "00000000000")
Simple transformation formula examples
Convert an amount into an amount with fixed 2 decimal places after the comma
NUMBERFORMAT(model.Payments.InstructedAmount, "#.00")
Remove the decimal separator, produce an amount in pence / cents
REPLACE(NUMBERFORMAT(parameter,"0.00"), ".", "", false)
Remove line breaks from the postal address without a regular expression, and truncate to 70 characters
LEFT(REPLACE(model.Payments.Debtor.PostalAddress.AddressLine, "\n", " ", true), 70)
Remove all non-numeric characters with a regular expression
RIGHT(REPLACE(parameter, "[^0-9]", "", true),6)
REPLACE(model.Payments.DebtorAccount.Identification.Number, "[^0-9]", "", true)
Calculate a weighted check sum
The below expression adds the 9th checksum digit to an US ABA routing number, should the user be entering only the significant 8 digits. The RIGHT(NUMBERFORMAT(10 – VALUE(), “#”, 1) is a crude implementation of modulo 10.
CASE(
LEN(parameter), 9, parameter,
8, parameter&RIGHT(NUMBERFORMAT(10-VALUE(RIGHT(NUMBERFORMAT(
((VALUE(MID(parameter, 1, 1))+VALUE(MID(parameter, 4, 1)))+VALUE(MID(parameter, 7, 1)))*3+
((((VALUE(MID(parameter, 2, 1))+VALUE(MID(parameter, 5, 1)))+VALUE(MID(parameter, 8, 1)))*7+
VALUE(MID(parameter, 3, 1)))+VALUE(MID(parameter, 6, 1))), "#"),
1)),
"#"), 1),
RIGHT(parameter, 9))
Day number in a year (1-366)
The British BACS18 format contained a date format that really made me suffer: for the 1st of February 2016 it expected “ 16032” where 32 was the day count from the 1st of January. The below code took me a while; it uses the Gregorian calendar formula and predates the fact that if you start counting months from March, the length of the months oscillates 31-30-31…
CONCATENATE(" ", DATEFORMAT(parameter, "yy"),
NUMBERFORMAT(
ROUNDDOWN(275 * NUMBERVALUE(DATEFORMAT(parameter, "MM"),".","") / 9, 0) -
(ROUNDDOWN( (NUMBERVALUE(DATEFORMAT(parameter, "MM"),".","") + 9) / 12, 0) *
(1 + ROUNDDOWN( ((NUMBERVALUE(DATEFORMAT(parameter, "yyyy"),".","") –
4 * ROUNDDOWN (NUMBERVALUE(DATEFORMAT(parameter,"yyyy"),".","") / 4, 0) + 2) / 3), 0) ) )+
NUMBERVALUE(DATEFORMAT(parameter, "dd"),".","") - 30,
"000"))
Data model
To master the file format, you must first learn the data model, the ER’s configurable abstraction layer over the Dynamics database. Outbound vendor payments use the Payment model.
table {border-collapse: collapse;} th, td {border: 1px solid black; padding: 10px; text-align: left;}It provides generic payment attributes,
AttributeModel nodePayment date (user parm or journal date)model.Payments.RequestedExecutionDateAmountmodel.Payments.InstructedAmountISO payment currency (journal line currency)model.Payments.CurrencyJournal line number (see Line counters)model.Payments.PaymentIdentifications.SourceBusinessEntityDescriptionPayment / Notemodel.Payments.PaymentsNotesVoucher+RecId (a unique line ID)model.Payments.PaymentIdentifications.EndToEndIdentificationDate of todaymodel.CreationDateTime
our bank details,
AttributeModel nodeOur name (company name)model.Payments.Debtor.NameOur full address (company address)model.Payments.Debtor.PostalAddress.AddressLineName of our bankmodel.Payments.DebtorAgent.NameOur bank account numbermodel.Payments.DebtorAccount.Identification.NumberOur IBANmodel.Payments.DebtorAccount.Identification.IBANRouting number of our bankmodel.Payments.DebtorAgent.RoutingNumberBIC of our bankmodel.Payments.CreditorAgent.BICFI
and their (beneficiary) bank details:
AttributeModel nodeTheir name (vendor’s name)model.Payments.Creditor.NameTheir full address (vendor’s payment address)model.Payments.Creditor.PostalAddress.AddressLineName of their bankmodel.Payments.CreditorAgent.NameTheir bank account numbermodel.Payments.CreditorAccount.Identification.NumberTheir IBANmodel.Payments.CreditorAccount.Identification.IBANRouting number of their bankmodel.Payments.CreditorAgent.RoutingNumberBIC of their bankmodel.Payments.CreditorAgent.BICFIThe post Electronic Reporting (ER) Cookbook appeared first on ER-Consult.
Старый 17.04.2017, 14:07   #2
trud is offline
trud
1,039 / 1635 (57) ++++++++
Записей в блоге: 1
Несколько вопросов к автору:
1. можно ли это использовать как полноценную замену отчетности - типа у нас есть требования десятка отчетов(типа накладных и т.п.). мы можем создать модель данных с необходимыми таблицами(что не очень сложно) и сделать так чтобы пользователи дальше уже сами делали эти отчеты? Как я понял это будет заполнение шаблонов Excel. соответственно интерфейсно хотелось бы чтобы это были кнопки на формах, по нажатию на которые открывался Excel.
или все же это не настолько мощная утилита?
2. почему Day number in a year (1-366) было не сделать просто дисплей методом в АХ(использую функцию dayofYr()) . или это трудоемко?
Старый 17.04.2017, 15:32   #3
belugin is offline
belugin
Аватар для belugin
4,622 / 2925 (107) +++++++++
Записей в блоге: 5
Можно разметить шаблон Excel названиями ячеек а потом связать участки шаблона с даннами в редакторе формата. Оналайн редактора Excel нет - только вот так: 1) Создание шаблона 2) Импорт шаблона 3) Связь с моделью данных
ER не поддерживает вызовы методов с неконстантными параметрами. Если создать display method без параметров, надо было бы его протаскивать через модель данных - то есть дальше формат мог бы работать только с измененной моделью и ее пришлось бы поддерживать.
И еще это потребовало бы изменения X++ кода и распространения его.
Последний раз редактировалось belugin; 17.04.2017 в 15:53.
За это сообщение автора поблагодарили: alex55 (1).
Старый 17.04.2017, 16:22   #4
EVGL is offline
EVGL
Banned
4,445 / 3001 (0) ++++++++++
Благодарю, добавить особо нечего. Кастомные методы стараюсь не использовать, до сих пор пришлось сделать только один: для перекодирования счетов ГК из одного плана в другой через Default consolidation account.
Старый 17.04.2017, 16:27   #5
trud is offline
trud
Записей в блоге: 1
Спасибо.
интерестно а вот это "работающий" процесс. т.е. можно применять для замены реальных отчетов SSRS? Какие есть ограничения-особенности
Старый 17.04.2017, 16:40   #6
belugin is offline
belugin
Аватар для belugin
Записей в блоге: 5
Спасибо.
Так же как Office Open XML отчеты в Ax2012 (в российской локализации) отсутствует возможность пакетной печати. То есть результаты пакетных заданий складываются в отдельную табличку но пользователь может распечатать их только интерактивно.
Так, в-принципе, отчеты формируются тем же OOXML и либо отдаются в браузер либо складываются в Document Management. Наверняка есть какие-то органичения по отношению к тому, что можно вытворить тем же способом через X++ но я их не назову так сразу.
За это сообщение автора поблагодарили: trud (2).
Старый 18.04.2017, 05:39   #7
trud is offline
trud
Записей в блоге: 1
А диалог можно вывести? т.е. самый простой сценарий- добавить на форму клиентов кнопку запрограммировав вывод диалога с 2 датами(С и По) и в результате хотим получить отчет который показывает данные клиента + данные проводок по клиенту зафильтрованные по введенным датам в диалоге.
т.е. программист описывает 2 ентити - клиенты и проводки, пишет метод фильтрации. а пользователь уже делает себе отчет и шаблон.
такие сценарии возможны? и есть что-нибудь подобное в стандарте?
Старый 18.04.2017, 08:55   #8
belugin is offline
belugin
Аватар для belugin
Записей в блоге: 5
Да,
  1. Есть User Input Parameter - это источник данных, который показывает запрос на ввод значения (только нельзя управлять их порядком)
  2. Есть функция FILTER которая отбирает записи по условию транслируя формулу в SQL
  3. Программист может сделать запрос на X++ и отфильтровать источник данных "Записи таблицы" передав в качестве параметра Query
см. также Обзорное описание
Старый 21.04.2017, 16:28   #9
EVGL is offline
EVGL
Banned
Черт, в последней версии приложения появилась встроенная функция DAYOFYEAR. Столько красивой алгебры впустую...
Старый 08.08.2017, 19:33   #10
mnt_dx is offline
mnt_dx
Axapta Retail User
1,749 / 158 (9) ++++++
Не знаю как вы все, я вот этот GER совсем не понял и термины "easily" и "customizable" к нему по мне никак не применимы. Для отчетов проще привлечь таки программиста.
Старый 27.09.2017, 23:19   #11
DSPIC is offline
DSPIC
Боец
1,077 / 1243 (44) ++++++++
У меня два вопроса:
1. Можно лі сделать возможным передачу параметров прі вызове метода табліцы?
2. Можно лі как-то упростіть следуюшій сценарій: у нас есть таблица CompanyInfo, которая участвует во многих конфигурациях. При добавлении нового поля, приходится ручками пройтись по всем конфигам и протянуть это поле. Весьма трудоемко. Пример: некоторые партнеры предоставляют внешние решения для печати отчетов. На выходе аксапты им нужен XML, а дальше они его трансформируют куда-то еще, в PDF например. CompanyInfo присутсвует во всех отчетах. Добавление нового поля сулит кучу времени по перенастройке и тестированию этого огорода. Как эту проблему можно решить, позволяет ли архитектура это сделать? Пока на ум приходит написать сбоку кнопку, которая сделает это автоматически. Может есть более интересные варианты?
Sorry for my font...
Последний раз редактировалось DSPIC; 27.09.2017 в 23:22. Причина: Е nt
Старый 28.09.2017, 00:01   #12
думаю, что Макс Белугин может ответить на этот вопрос самым компетентным образом.
однако, сразу хочу сказать, что GER сейчас развивается очень мощно.
поэтому для GER особенно важна версия системы.
думаю, что стоит указать вплоть до билда.
Старый 28.09.2017, 00:37   #13
EVGL is offline
EVGL
Banned
Кстати, если он так развивается, то что мешает добавить
DIV
MOD
и добавить целочисленный параметр 'scope' для независимой нумерации с помощью элемента Counter?
Старый 28.09.2017, 01:09   #14
EVGL is offline
EVGL
Banned
Сообщение от DSPIC Посмотреть сообщение
У меня два вопроса:
1. Согласно https://docs.microsoft.com/en-us/dyn...d-ops/toc.json, можно, но только констант.
2. Сделать метод типа CompanyInfo.toString() чтобы сериализовать все возможные поля, а потом реализовать функцию наподобие SPLIT(), но которая бы реагировала на символ-разделитель чтобы заново разбить на составные части.
Последний раз редактировалось EVGL; 28.09.2017 в 01:16.
За это сообщение автора поблагодарили: trud (4), mazzy (2).
Старый 28.09.2017, 02:00   #15
DSPIC is offline
DSPIC
Боец
Версия
Installed product version : Microsoft Dynamics 365 for Operations (1611)
Installed platform version : Update5 (7.0.4475.16165)
Касательно 1-го вопроса. Нашел в коде заготовку, для передачи параметров в метод таблицы. Но то ли это только заготовка, то ли я неверное использую синтаксис в выражении.
Вот кастомный метод на таблице, принимающий один стринговый параметр. Если указать параметр как на картинке, то валидатор не пропускает. Если без параметра, то позволяет сохранить
Далее при запуске, естественно, имеем стек трейс, так как параметр в табличном методе обязательный. Валимся на этом методе
Что тут видно - передача параметров таки предусмотрена, даже типы приводятся, и даже целых 5 штук можно передать (пять, Карл!)). Но каков должен быть синтаксис в редакторе формулы, чтобы они сюда дошли, пока не понятно и пока не хватает крови докопать.
Последний раз редактировалось DSPIC; 28.09.2017 в 02:04.
Старый 28.09.2017, 09:21   #16
belugin is offline
belugin
Аватар для belugin
Записей в блоге: 5
1) Корректный синтаксис для таблиц x.'method()'("Параметр")
2) Недавно добавили возможность вызова с неконстантными параметрами
71
https://fix.lcs.dynamics.com/Issue/R...&bugId=3851630
72
https://fix.lcs.dynamics.com/Issue/R...&bugId=3852876
За это сообщение автора поблагодарили: EVGL (2), DSPIC (17).
Старый 28.09.2017, 09:27   #17
belugin is offline
belugin
Аватар для belugin
Записей в блоге: 5
У нас нет функциональности для переиспользования таких вещей.
Нельзя ли несколько отчетов строить на одной и той же модели?
Если вы направите ваши вопросы в Yammer, то вопрос прочитает не только я, но и другие люди из нашей команды
Старый 28.09.2017, 11:30   #18
1.
Майкрософт меняет адреса и ссылки на своих ресурсах. Сильно опасаюсь, что и Яммер не минует чаша сия. Поэтому, если хотите оставить свои вопросы и ответы на долгое время, лучше написать здесь.
2.
Думаю, что другим людям из команды можно и axforum почитать.
Ведь никто не гарантирует от них ответы ни на яммере, ни на аксфоруме. А здесь своих пользователей все же больше.
3.
Уводить дискуссию на другой ресурс - невежливо.
Давайте обсуждать здесь.
Старый 28.09.2017, 13:00   #19
belugin is offline
belugin
Аватар для belugin
Записей в блоге: 5
Я не увожу никого - просто информирую. Я ж не отказываюсь обсуждать тут. Более того, привожу ссылки на аксфорум если тут возникает вопрос, на который сам не могу ответить.
AxForum:
  • на русском языке (проще читать нам, но нет западной аудитории)
  • постоянные ссылки
  • доступен поисковикам
  • не знаю, есть ли подписка на таги (т.е. люди из команды могут тупо подписаться на тег GER?)
  • вежливо по отношению к администрации
Yammer:
  • на английском языке
  • нет доверия к постоянности ссылок
  • официальный канал (люди из команды там уже присутствуют и прочим microsofties не надо специально решистрироваться)
  • есть подписка на таги (топики)
  • в целом возможности беднее
Последний раз редактировалось belugin; 28.09.2017 в 13:14.
Старый 28.09.2017, 13:27   #20
вежливо по отношению к остальным участникам axForum, конечно )
rss по тегу Добавлена фича: можно получать rss потоки по тегам.
electronic reporting, erconsult, ger
daxdilip: Book Review - Microsoft Dynamics AX 2012 Reporting CookBook Blog bot DAX Blogs 0 07.01.2014 01:12
palleagermark: Book review: Microsoft Dynamics AX 2012 Reporting Cookbook Blog bot DAX Blogs 0 28.11.2013 20:12
kamalblogs: Dynamics Ax 2012 Reporting cookbook published & 5 reasons why you should go for it Blog bot DAX Blogs 1 20.10.2013 15:12
kamalblogs: Dynamics Ax 2012 Reporting cookbook published & 5 reasons why you should go for it Blog bot DAX Blogs 0 30.09.2013 10:11
NAV reporting: Building a Matrix Report in Microsoft Dynamics NAV 2009 SP1 Blog bot Dynamics CRM: Blogs 0 28.08.2009 18:26
Часовой пояс GMT +3, время: 15:56.
