Старый 27.03.2017, 11:11   #1
dynamicsaxhints: What is wrong: crossCompany update job in AX 2012
Источник: http://dynamicsaxhints.blogspot.com/...pdate-job.html
I want to challenge you today to find an error in the following update job. Do not pay attention on the functional part. I agree, the job can be rewritten, but let's assume it must be done this way.
static void crossCompanyUpdate(Args _args)
CustTable custTable;
CustGroup custGroup;
PaymTermId oldPaymTermId = 'Net10', newPaymTermId = 'Net11';
ttsBegin;
// find all companies with oldPaymTermId
while select crossCompany custGroup
group by custGroup.dataAreaId
where custGroup.PaymTermId == oldPaymTermId
changeCompany(custGroup.dataAreaId)
// disable update method
custTable.skipDataMethods(true);
// set newPaymTermId
update_recordSet crossCompany custTable
setting PaymTermId = newPaymTermId
where custTable.PaymTermId == oldPaymTermId;
ttsCommit;
Post your ideas into comments. I will open comments and post my solution in one week. Have fun :-)
Dynamics AX Sustained Engineering: Announcing Cumulative Update 8 for Microsoft Dynamics AX 2012 R3 Blog bot DAX Blogs 0 20.11.2014 04:16
DAX: Microsoft Dynamics AX 2012 R3 is now available! Blog bot DAX Blogs 1 02.05.2014 23:00
Dynamics AX Sustained Engineering: Announcing Cumulative Update 4 for Microsoft Dynamics AX 2012 & Microsoft Dynamics AX 2012 Feature Pack 1 Blog bot DAX Blogs 0 05.12.2012 01:11
Часовой пояс GMT +3, время: 15:05.
