Старый 09.03.2017, 04:17   #1
waldo: Microsoft Dynamics NAV Source Code Analysis – Triggers & Procedures
Источник: https://dynamicsuser.net/nav/b/waldo...ers-procedures
On my last blogpost on Source Code Analysis (which focused on the LineCount), I got the remark whether it would be interesting to drill into “statements”. I didn’t really know what he meant with it – but it made me think and drill down into the usage of the procedures.
You might remember we talked about the “places” in NAV where we were writing code, like: OnValidate trigger, custom functions, OnInsert, .. but also OnDrillDown on a control of a page .. these things. And the more you drill into it, the more things you wann find out ;-). So, the below on what came to my mind during this quest.
What are the places we write code?
In order to get some stats on that, we need to first define what we mean. Well, I’m interested in the procedure types, like “OnInsert”, “OnValidate”, but also the created functions. Well, here is the entire table – and you see, most code is on manually created functions, but still, there is a significant amount is on triggers:
Count Name 24676 Procedure 5948 OnValidate 4465 OnAction 2218 OnDrillDown 1907 OnAfterGetRecord 1281 OnPreDataItem 1063 OnLookup 982 OnOpenPage 476 ExportOnBeforePassVariable 442 OnPreReport 440 OnRun 398 OnDelete 375 OnAssistEdit 371 OnInit 311 OnPostDataItem 308 OnAfterGetCurrRecord 303 OnInsert 244 OnNewRecord 169 OnModify 162 OnRename 146 OnFindRecord 130 OnQueryClosePage 122 Event 114 OnDeleteRecord 111 OnInitReport 94 OnNextRecord 74 OnPostReport 65 ExportOnBeforePassField 63 OnInsertRecord 49 Documentation 48 ExportOnAfterGetRecord 44 OnModifyRecord 24 ExportOnPreXmlItem 23 OnClosePage 18 ImportOnBeforeInsertRecord 16 ImportOnAfterAssignVariable 13 OnPreXmlPort 9 ImportOnAfterAssignField 8 OnPostXmlPort 7 OnBeforeOpen 6 ImportOnAfterInsertRecord 4 OnInitXmlPort 2 ImportOnAfterInitRecord
The most used functions
Well, to be honest, this isn’t going to be very “true” stats, because I was not able to measure the amount of “OnModifies” or “OnInserts” or any of these trigger-calls for that matter. So I’m just focusing on all created functions/procedures – you know, the ones you can create yourself. Here is the Top 10 functions mostly used “somewhere” in C/AL:
FullNameWithID UsedByCount Table.PROCEDURE
156
Report.PROCEDURE
155
Codeunit.PROCEDURE
150
Table.PROCEDURE
148
Codeunit.PROCEDURE
126
Codeunit.PROCEDURE
124
Codeunit.PROCEDURE
120
Codeunit.PROCEDURE
113
Report.PROCEDURE
111
Codeunit.PROCEDURE
108
Note: It does NOT count the OnRun-trigger of a codeunit – so the Sales-Post.OnRun is not taken into account, or any “CODEUNIT.RUN” for that matter. But let’s be honest – we shouldn’t be calling code like that anyway! (no, we shouldn’t!)
Most used function names
So, let’s drill into naming conventions. First, just as a teaser, I like to know what the most used function name is – no – let’s show the Top 10 of most used names:
Count Name 238 InitializeRequest 104 Code 93 ShowDimensions 77 GetLocation 75 Initialize 69 Caption 57 ValidateShortcutDimCode 50 Load 50 SetUpNewLine 48 GetItem
Surprised? I asked this question on Twitter, you here you see the results – most of them were completely wrong :-).
To try to not confuse you (too much), there is a difference between the amount of times someone used a certain name to create a function (the above table), and the amount of times a certain function was used in some code.. . Let’s see about the latter one. Here are the function names, that are most used in C/AL code:
Name UsedByCount AddError
869
MATRIX_OnDrillDown
596
454
MatrixOnDrillDown
440
ShowDimensions
310
GetLocation
267
FilterReservFor
264
AddElement
264
MATRIX_GenerateColumnCaptions
212
UpdateSubform
192
GetItem
185
Initialize
176
Most Used Function prefixes
That made me think – what about prefixes. Well, that’s somewhat more difficult, because function prefixes can consist of a variaty of number of chars. So I decided to:
  • Only focus on prefixes with 2,3,4,5 and 6 characters
  • Don’t include the events (which basically start with “On”)
  • And only take the ones that make sense to me, like exclude “Ge”, because it most likely “Get” is the intended prefix.
3207 Get 2373 Set 1233 Update 1093 Calc 1079 Check 869 Show 845 Insert 842 Init 822 Create 700 Export 507 Is
This is the top – and I like all of them ;-).
Unused functions
Vjeko came to me, and said – hey – you should try to list the functions that are NOT used anymore. Well, yeah, he kind of has a point – but I didn’t really think it was useful to do that, as Microsoft probably does their own analysis .. but still, it triggered me, so I did some queries. And I was amazed by the outcome. Really .. the amount of unused functions is a dazzling 1543, spread over 413 Pages, 416 Codeunits, 356 Tables and 358 Reports. And this is what i have taken into account:
  • Only self created functions/procedures
  • Left out the event subscribers
  • Left out all functions from Codeunit 1 (as these are called from the runtime)
  • Left out all the functions from “library-Random”, as there are functions for the testability framework
And still that many. Probably all of them having their own story, I’m sure, but I’m also sure that a lot of them are quite frankly “boat anchors“. I can’t just print them all here on the blog, but let’s just shed a light on two random cases:
Codeunit.PROCEDURE
As said, this function is never used .. although it has quite a lot of code! For me, this is a real boat anchor. Because we can find a “CheckWarehouse” at many locations – also on SalesLine – so my assumption is that it was redesigned, but left in CU80 .. . We can find more in CU80, by the way.. .
Codeunit.PROCEDURE
This is a type of function that I come across quite frequently. This function only returns the value of a text constant, by:
EXIT(myTextConstant);
Thing is, the function is never used, but the text constant is used all over that codeunit. So – what is the point of the function?
Local or global functions
We always advocate “be as local as possible”. Only methods should be global, all the rest should be local. Well, at least that’s the guideline .. so I though – let’s see how many are local and how many are global. These are the results:
  • Local Functions: 13481
  • Global Functions: 11195
Download
I exported the object-collection that I created to create this blog. You can find all results in that. So if you’re interested in all unused functions, you can figure that out from this download: NAV_10_15140_BE_ProcsFunctions
Disclaimer
As I put in my previous blogpost, all this data was crunched by an internal tool that I can’t share, and is still in BETA. Although I have no reasons to doubt the outcome (and believe me, when I saw the unused functions, I sure doubted our tool but after quite a lot of checks, conclusion was that it has to be right), I just can’t officially guarantee the 100% correctness of the results. If you have any reason to doubt, please contact me :-).
NAV Team: Upgrading from Microsoft Dynamics NAV 2009 R2 or Microsoft Dynamics NAV 2009 SP1 to Microsoft Dynamics NAV 2015 Blog bot Dynamics CRM: Blogs 0 23.02.2015 13:00
NAV Team: The New Table Synchronization Paradigm in Microsoft Dynamics NAV 2013 R2 Blog bot Dynamics CRM: Blogs 0 27.03.2014 18:15
NAV Team: RDLC Report and Performance in Microsoft Dynamics NAV Blog bot Dynamics CRM: Blogs 0 09.03.2014 13:00
Часовой пояс GMT +3, время: 17:52.
