Старый 09.02.2017, 16:11   #1
organicax: cXML Purchase Send – Reviewing Data Errors
Источник: https://organicax.com/2017/02/08/cxm...g-data-errors/
There are times where data might not be formatted correctly or wrong data provided that will cause a purchase to be returned from the supplier. The supplier will often return an message that will give you an indication of what data is incorrect. This could be a missing part number, wrong contact information, missing address information for example. The purchase request form will allow you to see the errors. You can see and filter on the orders that have been return with an error and then address them with the owner of the purchase order.
Here is a quick overview
AX2012 R3.
Refer to this post for an overview of the cXML Purchase Order Send.
https://organicax.com/2017/02/08/cxm...-ax2012-r3-v1/
Cheers
Lachlan
Filed under: Procurement and sourcing
organicax: cXML Purchase Send – Merge objects overview Blog bot DAX Blogs 0 09.02.2017 16:11
organicax: cXML Purchase Order Request Send AX2012 R3 V1 Blog bot DAX Blogs 0 09.02.2017 16:11
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
Часовой пояс GMT +3, время: 00:34.
