Старый 04.02.2017, 03:29   #1
organicax: RFQ default payment terms
Источник: https://organicax.com/2017/02/03/rfq...payment-terms/
When you are setting up RFQ’s you might want to consider the default payment terms. There is a parameter that will default from the procurement parameters. You might want to consider what you set this too and published to the vendors. For example you might already have negotiated payment terms with a vendor. So when the RFQ is created the default from the RFQ to the purchase order.
Here is a quick overview
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Procurement and sourcing
organicax: Item cost default on movement journal Blog bot DAX Blogs 0 06.11.2016 03:15
organicax: Stopped for Purchase Orders – Default Order Settings Blog bot DAX Blogs 0 09.04.2016 00:29
organicax: Stopped for Inventory – default order settings Blog bot DAX Blogs 0 09.04.2016 00:29
organicax: Stopped for sales order – default order settings Blog bot DAX Blogs 0 08.04.2016 02:19
dynamicsaxtraining: Paying a Vendor Blog bot DAX Blogs 0 22.03.2012 22:11
Часовой пояс GMT +3, время: 09:22.
