Старый 03.02.2017, 21:18   #1
organicax: RFQ expiration date – days offset
Источник: https://organicax.com/2017/02/03/rfq...e-days-offset/
If you are setting up request for quotes it helps to go through the parameters to see if they can help save you some time updating fields. One is the expiry date. You can set a default adjustment to the expiry date in the procurement parameters. This will default to the header and get pickup in the lines.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Procurement and sourcing
organicax: Vendor hold release date Blog bot DAX Blogs 0 09.10.2016 19:12
organicax: Session date selection in AX7 Blog bot DAX Blogs 0 05.10.2016 09:11
organicax: Receipt date is not valid on customer calendar Blog bot DAX Blogs 0 07.04.2016 20:13
axmfg: More about (dynamic) negative days Blog bot DAX Blogs 0 19.02.2015 23:16
Часовой пояс GMT +3, время: 09:21.
