Старый 02.02.2017, 14:11   #1
organicax: How is the list of main accounts in budget control configuration determined
Источник: https://organicax.com/2017/02/01/how...on-determined/
If you are looking to setup budget control then you might want to consider the type of accounts that you can use it to track. This is limited to accounts like expense, total, P&L etc. For example you won’t see asset accounts on there. So this is handy if you are doing category based purchases as you normally post to an expense account. But if you purchase and stock products then this should post to an assets account in which case you won’t trigger budget control on these.
Here is a quick overview of where to find the main account setup in budget control.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Budgeting
dynamicsax-fico: Budget control for fixed assets – Part 1: AX2012 Blog bot DAX Blogs 0 16.04.2016 20:16
dynamicsax-fico: A note on budgeting on total accounts Blog bot DAX Blogs 0 08.04.2016 09:11
ax_gfm_framework_team: Integrating a Source Document with Budget Control Blog bot DAX Blogs 0 18.07.2012 00:11
Часовой пояс GMT +3, время: 17:36.
