Старый 01.02.2017, 05:22   #1
organicax: Project budget balances vs cost control forms
Источник: https://organicax.com/2017/01/31/pro...control-forms/
If you are working with projects then working out what cost control mechanism that will work for you is something that you might want to experiment with. There is both forecasts and budget. There are subtle differences in the detail that you can put against each. As well different ways they integrate with other modules in AX.
It’s worth understanding how they both behave relative to what data is displayed in forms. For example the cost control form and the project budget balances form.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Project management and accounting
dynamicsax-fico: Project cost allocations Blog bot DAX Blogs 0 02.10.2016 17:16
dynamicsax-fico: Budget control for fixed assets – Part 1: AX2012 Blog bot DAX Blogs 0 16.04.2016 20:16
dynamics-coe: “Cost accounting” for multi-level process manufacturing Blog bot DAX Blogs 0 11.02.2016 22:12
emeadaxsupport: How General Budget Reservations will update Committed Cost on Project Contracts Blog bot DAX Blogs 0 21.05.2015 21:12
emeadaxsupport: Project indirect cost components in AX 2012 Blog bot DAX Blogs 0 31.07.2014 22:11
Часовой пояс GMT +3, время: 02:41.
