Старый 24.10.2016, 17:11   #1
organicax: Vendor invoice line approved by purchase order line requester modification
Источник: https://organicax.com/2016/10/24/ven...-modification/
In a previous post we had a look at the workflow of assigning a invoice line level approver from the purchase order line requester. In this post we’ll have a look at the objects that you need to create the new participant provider.
If you want a step by step view on how to create a new participant provider you can have a look at this post.
Here is a quick overview.
AX2012 R3 CU11.
If you want a copy of the XPO in the video you can find it on my onedrive.
https://1drv.ms/u/s!AjyKH96OSFD9gRHYXoe073pCFh_L
Cheers
Lachlan
Filed under: Accounts payable
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
Nav developer: Table Information including Index information (Usage, Blocks and Reads) Blog bot Dynamics CRM: Blogs 0 25.08.2009 19:34
NAV Sustained Engineering Team Blog: Index Usage Query Blog bot Dynamics CRM: Blogs 0 26.02.2008 12:29
Часовой пояс GMT +3, время: 08:42.
