Старый 28.09.2016, 02:11   #1
organicax: Enabling an employee in the MES, shop floor
Источник: https://organicax.com/2016/09/27/ena...es-shop-floor/
If you have resources that you want to enable to use the MES job registration screen in production then there are a few things that you will need to setup. This video gives you the basic flow of where to setup the employee, time details enough that they can log onto the job registration screen.
Here is a quick overview.
AX2012 R3 CU11
I don’t try to cover each field of the time registration setup as there are a lot of options that you will need to consider, we’ll cover them in follow-up posts.
Cheers
Lachlan
Filed under: Production control
organicax: Employee Self Service Workspace Blog bot DAX Blogs 0 03.04.2016 15:11
Пожелания на следующие версии - Shop Floor control/Manufacturing execution/Time and attendance Slava Chernenko DAX: Функционал 8 17.10.2011 18:35
DynamicsAxSCM: Microsoft Dynamics AX 2012: Where is the Shop floor control module? Blog bot DAX Blogs 0 03.08.2011 09:11
axinthefield: Podcast: Dynamics AX Shop Floor Control Blog bot DAX Blogs 0 17.06.2011 18:11
Часовой пояс GMT +3, время: 00:53.
