Старый 27.09.2016, 14:11   #1
organicax: cXML punchOut user flow
Источник: https://organicax.com/2016/09/27/cxm...out-user-flow/
I’ve done posts in the past about the punchOut flow. This one is basically the same but using the cXML punchOut protocol handler for AX2012. To the user they won’t see any difference as they shouldn’t because the protocol is what passes the data between the procurement site and the suppliers site. In this example the external site is Staples but it could be used with many different supplier sites that support cXML.
Here is a quick overview.
For notes on downloading the cXML punchOut protocol for AX2012 see this post
Cheers
Lachlan
Filed under: Procurement and sourcing
organicax: cXML punchOut protocol handler for AX2012 Blog bot DAX Blogs 0 27.09.2016 14:11
organicax: cXML punchout protocol handler installation for AX2012 R3 Blog bot DAX Blogs 0 27.09.2016 14:11
organicax: User preference for date, time and number format in the new Dynamics AX Blog bot DAX Blogs 0 15.03.2016 23:11
organicax: AX R3 Warehouse in manufacturing – end to end basic flow. Blog bot DAX Blogs 0 09.03.2016 16:11
DynamicsAxSCM: Change license plate, split quantity, skip and override location during inbound put away Blog bot DAX Blogs 0 27.11.2015 16:11
Часовой пояс GMT +3, время: 11:44.
