Старый 17.09.2016, 01:16   #1
organicax: Item coverage copy setup
Источник: https://organicax.com/2016/09/16/ite...ge-copy-setup/
If you are setting up new items in AX and you plan to use master planning you might want to consider using the copy function to copy the item coverage. This will allow you to use an existing item as a template and copy it to a range of other items. This is also useful if you are changing your coverage settings.
Here is a quick overview.
AX2012 R3 Cu11
Cheers
Lachlan
Filed under: Supply chain planning
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
dynamicsaxtraining: Item setup: Inventory dimension group Blog bot DAX Blogs 1 05.10.2010 15:35
DynamicsAxSCM: Sales and purchase prices in relation to the item price setup in Microsoft Dynamics AX 2009 Blog bot DAX Blogs 0 11.02.2010 09:05
Часовой пояс GMT +3, время: 06:58.
