Старый 22.07.2016, 22:13   #1
organicax: Catalog doesn’t show hierarchy for new call center
Источник: https://organicax.com/2016/07/22/cat...w-call-center/
If you are trying to setup a new call center and a related catalog, if the catalog doesn’t display a hierarchy the likely you have missed setting up the retail store product attributes. There is a parameter in the attributes called category hierarchy that you will need to assign.
Here is a quick overview.
AX2012 R3 CU10.
Just as a reminder you won’t be able to setup the store product attributes unless you have associated the channel to an organization hierarchy. See this post.
Cheers
Lachlan
Filed under: Retail
organicax: Setting up modes of delivery on a call center Blog bot DAX Blogs 0 14.03.2016 02:40
organicax: Creating a coupon for a discount and using on a call center sales order Blog bot DAX Blogs 0 11.03.2016 05:17
organicax: Enable price control on a call center Blog bot DAX Blogs 0 09.03.2016 03:28
emeadaxsupport: AX for Retail R3 CU8 Call Center: Fix for Customizing CRT Pricing Engine Blog bot DAX Blogs 0 01.07.2015 19:11
emeadaxsupport: Enabling the new Call Center Channel User Functionality in AX 2012 R3 Blog bot DAX Blogs 0 02.09.2014 18:11
Часовой пояс GMT +3, время: 09:54.
