Старый 10.05.2016, 17:11   #1
organicax: WMS mobile device menu – Display disposition code
Источник: https://organicax.com/2016/05/10/wms...position-code/
In a previous post we had a look at warehouse disposition codes. If you are using disposition codes you can display them on the mobile device menus, in this example a purchase receive.
Here is a quick overview.
AX2012 R3 CU9
Cheers
Lachlan
Filed under: Warehouse management
organicax: WMS Mobile device menu – Display batch disposition codes Blog bot DAX Blogs 0 10.05.2016 17:11
organicax: Assigning a WMS work template to a disposition code Blog bot DAX Blogs 0 10.05.2016 10:11
DynamicsAxSCM: Warehouse Mobile Device Portal Blog bot DAX Blogs 0 23.02.2015 22:12
DynamicsAxSCM: Receiving a pallet with mixed items based on a packing structure using License plate receiving mobile device menu item Blog bot DAX Blogs 0 18.09.2014 22:12
Часовой пояс GMT +3, время: 10:08.
